f4i engine rebuild...seized AGAIN?!
Old Oct 3, 2009 | 11:00 AM
  #61
pitpoundfam's Avatar
pitpoundfam is a decent person
Re: f4i engine rebuild...seized AGAIN?!
does anyone know how to bypass the ecu to start the bike?
Old Oct 3, 2009 | 11:02 AM
  #62
you know, like before they started the whole (putting a comp. in the bike thing)
Old Oct 3, 2009 | 01:32 PM
  #63
Towlieee's Avatar
yes, get rid of the fuel injection and bolt some carbs on the bike
Can't just bypass the ECU, the reason there is a ECU is because the bike is fuel injected, and it since it has a ecu im sure the ecu also controls the ignition timing, and I'm sure it controls more
Old Oct 9, 2009 | 03:52 PM
  #64
DirtyToes's Avatar
DirtyToes is a decent person
FUUUUUUUUUUUUUUUUUCK!!!
it blew AGAIN!
1. put the new head gasket in
2. finally put her back together (after fixing a buncha FI codes except #23)
3. sounds fine
4. as soon as i exit driveway, sounds like it's running on 2-3 cylinders
5. ride it a 100ft, i look back and a ton of smoke is shooting out the exhaust.
6. i though w/e, it's from the airbox or sum ****, but the smoking did not stop.
7. another 100ft back to the house...5 feet from my driveway, i hear what sounded like a chain falling off a sprocket, so i turn her off and push it the other 5ft.
8. tried to fire her up, SEIZED!!!!!
i'm FUCKED...right? woohoo!
Old Oct 9, 2009 | 04:02 PM
  #65
Originally Posted by DirtyToes
jesus ******* christ I DID IT!!
YYEAAAAAAAAAAAAAAAA!!!!
my homy sal came over, big dude weighing in @ 350lbs.
he asked if i had a long breaker bar, 4-foot 1/4" thick pole.
with the bike on the 12 bar, put that pipe around a half inch driver, on the clutch lock-nut, once twist, and walla, PISTONS ******* MOVED!
he went for a 2nd spin and broke by outter clutch cause i had vice grips connected to it...which i had an extra one.
read to break it in.
anyway, put everything back together, fired it up, let it warm up to 120, and took it for a spin, i rode it for 100feet, if don't give it gas, it does, and the whole time it runs/sounds like its running on 3 cyclinders.
my guess...i didn't install a new head gasket, so i got that on the way.
any other ideas before i put this bitch back together...again
it blew AGAIN!
3. sounds fine
i cant even believe what im reading if it took that much force to turn the motor over you clearly had an obstruction , had you taken it apart to see what it was you probably would have a running motor right now but instead you fucked your **** up ...
Old Oct 9, 2009 | 04:05 PM
  #66
Righteous 1's Avatar
Damn. Sorry bro. Go burn one and do something else for a few. You don't get along well with F4i motors!
Old Oct 9, 2009 | 04:12 PM
  #67
DirtyToes's Avatar
lol ^^ true dat...f4is, i get along with, their motors, not so much...if i didn't have so much custom parts and a clean frame on this bike, I would light the cursed son of a bitch on fire and post the video on here.
thanks for the support jackass
p.s. the motor was spinning freely/normal after i broke it loose with the breaker bar.
whats tripping me out is where the **** the oil/smoke was coming from...blown rings? but why how?!
Old Oct 9, 2009 | 04:17 PM
  #68
sorry didnt mean to be a dick i was just surprised to see you didnt check to see why the motor wouldnt turn over ...
as far as the smoke goes you may have cracked a piston or some thing while forcing it to turn over
  #69
lilspoony's Avatar
lilspoony is a decent person
take that **** back to the guy that rebuilt it. he fucked something up and needs to fix it.
no way a motor should blow after a rebuild...even if it sat for a year.
Old Oct 9, 2009 | 04:18 PM
  #70
Ethiopian's Avatar
Soup Mafia
it blew AGAIN!
3. sounds fine
just buy a used motor already.
Old Oct 9, 2009 | 04:19 PM
  #71
**** you could have even cracked a cylinder by using a breaker bar to turn it over if there was a nut or a bolt dropped in the motor
Old Oct 9, 2009 | 04:32 PM
  #72
DirtyToes's Avatar
hell ya ^^!! i was hoping that would be it
i feel like a dipshit idiot for spending so much time on this ************.whatever, at least i got to ride it for 2 more minutes...
ahhh...the memories.
i guess its back to riding my last toy
Old Oct 9, 2009 | 04:38 PM
  #73
buy a used motor and take the old one apart cause i want to know if it was a dropped bolt or not ...lol
i have two theories
1- dropped bolt
2- dropped valve
Old Oct 9, 2009 | 05:14 PM
  #74
DirtyToes's Avatar
i have two theories
1- dropped bolt
2- dropped valve
ohh ya, I'll get right on that boss. ...i hope you're wrong cause then i'm gonna feel like an even bigger dipshit.
I'm not getting near that piece of **** for at least another week, but sure i'll find out what's wrong with it.... i have a theory too
EDIT:
1 - retarded mechanic that rebuilt it
stuntin'_cbr
Feb 12, 2013 06:46 PM
Jeffknight27
Dec 3, 2012 10:55 PM
blayl
Nov 28, 2012 12:18 AM
blayl
Nov 27, 2012 02:06 PM
qfo
Nov 15, 2012 10:39 PM
