f4i engine rebuild...seized AGAIN?!
Old Sep 18, 2009 | 03:32 PM
  #41
cbr717's Avatar
cbr717 is a decent person
Re: f4i engine rebuild...seized AGAIN?!
Does all the pistons move a mm. Idk if they are the same at all but on my jetski the rod bearing on the crank went out and that piston was stuck but the other one would barly move. Maybe a bad bearing got put it
Old Sep 18, 2009 | 07:51 PM
  #42
ruffstunter87's Avatar
stuntridin....
ruffstunter87 is a decent person
my bike is at junkyard, i used the money to buy 18 pack of beer...
Old Sep 18, 2009 | 08:06 PM
  #43
DirtyToes's Avatar
DirtyToes is a decent person
well i had the middle 2 filled with oil so i could only see pistors #1 and #4 (tdc ones)...and yes, they both moved, i'll check again tonight to see if the other 2 are moving as well.
you lucky sob
p.s. any advice on loosening the rod bearing bolts?
Old Sep 21, 2009 | 05:55 AM
  #44
DirtyToes's Avatar
Dot dot dot
{bump}
Old Sep 24, 2009 | 02:53 AM
  #45
duckchrt's Avatar
stunt rider
duckchrt is a decent person
it could be hydraulically locked, pull the plugs and try turning it over by hand and if not then use the starter... i would put something over the holes though like a rag or 4 rags to prevent getting fluid everywhere
Old Sep 24, 2009 | 05:30 AM
  #46
some one only read the first post ..lol
Old Sep 24, 2009 | 11:11 AM
  #47
stuntridin....
ebay motors got some deals..............
Old Sep 24, 2009 | 07:45 PM
  #48
B0arder606's Avatar
B0arder606 is an unknown quantity at this point
Start Ripping it apart. There is no real easy way to figure out what is wrong unless you pull it apart. Chances are if a bolt got dropped in or something then trying to bump start it jsut fucked it up more.
Old Sep 28, 2009 | 11:25 AM
  #49
DirtyToes's Avatar
**** that ^^ ... your idea is more like last resort.
next plan is to tow this ************ up the hill...roll down 50mph and pop her into 2nd...
thats how we get urrr donee
Old Sep 28, 2009 | 12:43 PM
  #50
Towlieee's Avatar
too lazy to read teh whole thread again
but your mechnic KNOWS what he is doing right? He didn't just rebuild a couple ATV's and dirt bikes then think he could tackle a inline 4 motor?
When the motor seized before, what was it, bad rod bearing? Was the crank replaced? What about the rod that seized?
Also when your trying to turn hte motor over, have you put a 1/2" driver on the bolt on the CRANK, and tried turning it with LOTS of force?
When my friends 600rr locked up, the started wouldn't turn it, and I couldn't get it to spin the tire from push starting it..
When I put a 1/2 driver on the crank, with LOTS of force I was able to just barely budge the motor.. Thats when I realized it wasen't a bolt or something broke off wedged in the motor, and was infact, damaged bearing/crank causing WAY to much drag
I wouldn't try hill starting it, if ANYTHING, attempt to turn with a wrench, but that could still end up causing damage..
Did you mechanic POSITIVELY lube everything WELL? WHen I build a motor, I just pour motor oil over every surface..
Another thing to do before ever starting a f4i motor that MIGHT help (prolly too late for your motor now)
Is right after a fresh rebuild, while the clutch is still off the bike, you can put a socket on the end of the oil pump, put the socket into a power drill, and spin the oil pump via a drill.. This will let you build full oil pressure to all parts of the motor. And if you wanted to get 'gangster' you could even turn the motor over by hand VIA the crank while spinning the oil pump, make sure the entire motor is 100% oiled before ever firing it up
Old Sep 28, 2009 | 01:14 PM
  #51
DirtyToes's Avatar
ya, i tried spinning the motor with the tiny little 12mm bolts on the right side....nearly broke the bolt...crank did not budge.
then took out the clutch and tried spinning it with the 32mm clutch bolt ...still nothing.
**** this ****.
Old Sep 28, 2009 | 07:11 PM
  #52
lilspoony's Avatar
lilspoony is a decent person
sounds like your mechanic fucked something up. take it back to him or another mechanic and see what he says. a motor shouldnt just lock up.
Old Sep 30, 2009 | 05:52 AM
  #53
DirtyToes's Avatar
jesus ******* christ I DID IT!!
YYEAAAAAAAAAAAAAAAA!!!!
my homy sal came over, big dude weighing in @ 350lbs.
he asked if i had a long breaker bar, 4-foot 1/4" thick pole.
with the bike on the 12 bar, put that pipe around a half inch driver, on the clutch lock-nut, once twist, and walla, PISTONS ******* MOVED!
he went for a 2nd spin and broke by outter clutch cause i had vice grips connected to it...which i had an extra one.
read to break it in.
anyway, put everything back together, fired it up, let it warm up to 120, and took it for a spin, i rode it for 100feet, if don't give it gas, it does, and the whole time it runs/sounds like its running on 3 cyclinders.
my guess...i didn't install a new head gasket, so i got that on the way.
any other ideas before i put this bitch back together...again
Old Sep 30, 2009 | 11:47 AM
  #54
600flipper's Avatar
420
600flipper is a decent person
Good for you buddy !
Old Oct 2, 2009 | 08:36 PM
  #55
E-Loc540's Avatar
540 BOYZ SUMO STUNTER
E-Loc540 is an unknown quantity at this point
Originally Posted by DirtyToes
I don't beleive in condensation.
not really, any moving surfaces should have oil on em and im pretty sure the cylinders are nikasil so they arnt going to rust...
Old Oct 2, 2009 | 08:38 PM
  #56
E-Loc540's Avatar
oh nevermind, well i never head of anyone needing all that leverage to turn a darn motor. All that work done to it and you re-use a head gasket????
  #57
MoHawk's Avatar
Post Whore Nazi
Originally Posted by joey1
if you do that i'll make chino start wearing the mohawk again
This comment creeps me out for one VERY obvious reason
Old Oct 2, 2009 | 08:39 PM
  #58
MoHawk's Avatar
Post Whore Nazi
Um... nevermind
Old Oct 2, 2009 | 08:40 PM
  #59
600flipper's Avatar
420
Old Oct 2, 2009 | 08:41 PM
  #60
MoHawk's Avatar
Post Whore Nazi
