powerband fuel map problem fastfingerJAY!!
Jay it was nice of you to give me that power commander and that powerband thanks. but i am having problems hooking it up. i found the power wire (red duh!) and the ground (no ****) but the other four wires are a mystery to me the blue wire that goes to my fuel injection i cant find there is just a bunch of springs and levers and ****. thought i found where the green one went turns out that i hooked it up to my lights or something because my headlights blew out. i think i have the powerband in the right spot by the capasitor like you said but i still need help
Re: powerband fuel map problem fastfingerJAY!!
Originally posted by Merlin
you need to have 1.21 gigawatts of power to the band...make sure you have the correct ohm grease in the plug too so it fluxes properly
I probubaly can guess your first problem already. Did you forget to diconnect the negative battery terminal? And I also forget to tell you those other four wires are for multiy bike hook ups. One more ? Where did you mount the powercomanader. If you mounted it on top of the triple action sensor, that will cause a reverse polarity and your timing will be in reverse
. But, an easy fix, put some aluminium foil over the top and it will react like a mirror and that problem solved.
. But, an easy fix, put some aluminium foil over the top and it will react like a mirror and that problem solved. hmm
mite need a diode! 16,000,000 ohms and full continuity out the other side. the resistance acts as a filter, kinda like if we put filter that didnt allow any retarded **** outta slothys mouth.. then he would say nothing.. follow?
