how to air box mod f4i
Old Dec 11, 2007 | 10:14 AM
  #141
Re: how to air box mod f4i
word .
Old Jan 4, 2008 | 02:06 PM
  #142
EEKENTERPRISES's Avatar
EEKENTERPRISES is a decent person
Did this last night.....clean air mod and removal of the tip over sensor as I still love that wheelie sensation!!!
The clean air mod will give you better low end for two reasons ... this is why racers love it.....
1- you don't get any of the hot oily air from the crank case in your airbox---Take an automotive spray gun, The air blowing by the small jet pulls paint from the canister and doesn't blow pressure into the can...... Same thing here, the exhaust blows by and pulls the hot air / oil from the crancase with it...
2- by hooking the crankcase vent tube up to the clean air valve it creates a vaccum in the crank case and that is good for a few extra horse power and a couple foot pounds of torque...OMR (aka the man) said..."it makes the bike better all around and alot of people agree ,i have even seen dyno test that show increased torque and horse power"
The stunters love it because it prevents a hydrolock situation from the bike being on its side and oil being dumped into the airbox from the breather tube....it has been argued over and over and proven, this is a great mod with no bad side effects whatsoever....
This is what it looks like stock....the directions are a bit confusing, throw 3 away, and hook 1 2 and 4 to the new t....
The pair valve removed....
1/2" Tee...it was very tight, had to vaseline the hoses to get them on, but better than too loose....
Here is a pic of the t with the hoses.....
How I sealed the airbox off, I have seen many methods, but looking around the garage I realized that some old tire valve cover caps fit perfectly and are hard enough to hold, through them in with a little epoxy and they were solid and fit perfect, looks factory...
Also here is the tipover sensor mod as well.... just cut that damn thing out and never worry about it again....
With windscreen off...
Remove the 2 screws holding the box in and disconnect the box...
Here it is removed and unclipped....
Cut off the connector and make sure there is enough room to reconnect if you want to reinstall in the feature, tie red and green together and cap white off....and clip back in....
Old Jan 5, 2008 | 05:39 AM
  #143
krazykyle85's Avatar
krazykyle85 is a decent person
you guys talk about taping the airbox.. i have tried this an noticed a diffrence but i thought about it wouldnt the stock idle do similar thing by adjusting fuel mixture... cause isnt it basically the ssame thing?
Old Jan 5, 2008 | 06:15 AM
  #144
DirtyToes's Avatar
DirtyToes is a decent person
thats why you have to re-adjust the idle (using the stock cable) after doing this mod.
Old Jan 5, 2008 | 09:49 AM
  #145
DSC's Avatar
DSC
anybody ever seen an f4i after it falls on the left side with this mod?!!
Old Jan 5, 2008 | 11:49 AM
  #146
ALSTAR's Avatar
ALSTAR is an unknown quantity at this point
so
will she suck harder if u take the reed valves out of the cam cover....?
and thanks everyone for the tips
cos i hadn't tried the adjust of the original idle
but i rember when i first did the 2nd cable mod there was advice suggesting the base idle setting should be left alone.......?
it just an air bypass i think....
haven't ridden it like a month now in between engine swaps and spraying
Old Jan 5, 2008 | 12:09 PM
  #147
yep alotta smoke.....lol
Originally Posted by ALSTAR
so
don't take out the reed valves because they make it so there is a vaccum affect only if you take them out at certain rpms there would be pressure instead of vaccum
Old Jan 5, 2008 | 12:14 PM
  #148
DSC's Avatar
DSC
thats an understatment
Old Jan 5, 2008 | 12:17 PM
  #149
well that means the mod works because normally all that oil would have gone into your air box
Old Jan 5, 2008 | 12:22 PM
  #150
DSC's Avatar
DSC
i know, it funny when it happens tho, i smoked out the lot
Old Jan 5, 2008 | 12:26 PM
  #151
ALSTAR's Avatar
wierd but ok i will leave them...........
Tar very much
Old Jan 5, 2008 | 12:29 PM
  #152
Towlieee's Avatar
smoke the lot out? Just lay my f4i on its left side you say?
Hell ya thats a lot easier then rolling one up
Old Jan 5, 2008 | 12:42 PM
  #153
DSC's Avatar
DSC
don't for get running its gotta be running i think!!
Old Jan 5, 2008 | 01:18 PM
  #154
da Liks's Avatar
da Liks is a decent person
Originally Posted by nags
The peoples bikes you ride dont know how to maintain them. Mine doesn't do that.
nor mine.. proper maintenance boys and girls!
Old Jan 10, 2008 | 10:22 PM
  #155
skidmark's Avatar
skidmark is a decent person
I did this a while ago just gutting the valve, but re-did it tonight using a proper T-fitting so thought I'd add to this thread. I used a 1/2 inch inner diameter fitting that I got from Home Depot for 67 cents. It fit percectly, nice and tight. I just used the 3 normal hoses and threw out the big one.
Another idea for vacum caps = use a few layers of electrical tape and cut some segments from the big hose you end up throwing out and shove em on (see 3rd pic).
ID:	204673   Click image for larger version
ID:	204674   Click image for larger version
Old Jan 11, 2008 | 03:15 AM
  #156
i jus heard today that it causes problems when you do it this way, i have mine like that an my bike is running like garbage.
i was told to completely cap off the two front nipples an the crancase vent jus run a huse towards the ground with a small filter an your good.
what do you guys think?
Old Jan 11, 2008 | 07:28 AM
  #157
J-Boogie's Avatar
J-Boogie is a decent person
subscribed
Old Jan 11, 2008 | 12:43 PM
  #158
Towlieee's Avatar
I think you heard wrong...
dozens of people have done this mod..
Old Jan 11, 2008 | 01:23 PM
  #159
skidmark's Avatar
who did you hear that from?
I had it done for a while already with just the gutted valve and it was running great. It should run the same with the T-fitting. If it's running wierd maby it's cuz the valve unit isn't plugged in
Sunday should be dry here so if I go ride i'll find out. If it runs like crap i'll plug in the valve and see what that does
Old Jan 14, 2008 | 02:32 PM
  #160
skidmark's Avatar
It wasn't dry but not raining so I rode anyway, the bike runs awesome!
