how to air box mod f4i
Re: how to air box mod f4i
i was curiouse i only have one idle screw on my bike.. it idles up fine it will go up to about 4 grand maybe more but it does get tight after
do i have too add another throttle idle cable to do this air mod or to help the bike in anyway ? thnaks
I did the clean air mod. to my 929 yesterday, and rode with it all day... didn't noticed any stronger idle or more torque...
But still nice to know I can't hydrolock my engine
Of course, if your ALWAYS stunting, always at 4k idle (wtf are you doing at 4k idle anyways? lol)
then it might not be a problem..
But if you cruise the streets, and run 1k idle like normal, then it'll idle real rough and shitty..
well i just did mine and instead of buying a t-bar(splitter thingy) i just flipped the stock splitter around so hose 4 can connect now i just need to ride but its raining
hopefully i did everything right and it works.......
hopefully i did everything right and it works....... Re: how to air box mod f4i
I did the mod a few weeks ago.. I just got the t-valve at a local hardware store... the hoses are 5/8 of an inch so a 5/8 inch fitting is kinda hard to shove in there so I got a 1/2 inch and a couple hose clamps.. works great!
I also didnt really notice any horse power but just feel better knowing i'm doing what I can to protect my motor! Just my
turn your second cable all the way down so it's not effecting the idle and set the factory one at 1100 rpm then turn your second cable up to where you like your idle for stunting see how it pulls on idle then turn the stock cable up or down a 1/4 turn and see how it effects the pull at idle ...
you may need to go up a little your may need to go down a little all bikes are different but you can dial it in so it will pull better at idle
I'm actually just about to do the idle cable mod soon.. I have the cable, but i'm waiting for my '04 1000RR throttle assembly to arrive so I can do it all at once.. once I get it all done.. I'll see how it feels. Thanks for the tip.
Just got done doing both the air box mod and the idle mod. Bike is running great, had no problems what so ever. Bike was running a little hot... I think it might be because I over filled it with oil, but around 4.3 quarts is fine right?
Yes, you ordered it for no reason. Hondas like Honda parts
I dont see overfilling the oil making the bike run hot. Thats still seems like a lot of oil, but not sure. I use 1 gallon in my F4i
