how to air box mod f4i
Old Jan 14, 2008 | 03:17 PM
  #161
DoodleF4i's Avatar
Re: how to air box mod f4i
you can do this without the T fitting by just gutting the little piece out..i did it to my f4i and it pulls idle a lot harder.
Old Jan 15, 2008 | 06:44 AM
  #162
Joe Bar's Avatar
Joe Bar is an unknown quantity at this point
Did someone try it with a 600RR ('03)?
Old Jan 15, 2008 | 09:55 AM
  #163
edit .
Old Jan 15, 2008 | 10:01 AM
  #164
Originally Posted by krazykyle85
i jus heard today that it causes problems when you do it this way, i have mine like that an my bike is running like garbage.
i was told to completely cap off the two front nipples an the crancase vent jus run a huse towards the ground with a small filter an your good.
what do you guys think?
Originally Posted by Towlieee
I think you heard wrong...
dozens of people have done this mod..
there are 100000 of these pair mod threads and as many people who have done them and had no problems ,so don't listen to the guy who has other problems and blames it on this mod......it works ,do it.
Old Jan 30, 2008 | 06:25 PM
  #165
Jeremy Dutch's Avatar
Jeremy Dutch is an unknown quantity at this point
what is the second idle cable? and where is it?
Old Jan 30, 2008 | 06:30 PM
  #166
i think most people use a 98 900 rr cable and you put it where the stock idle set screw is ...in between the two center throttle bodies
Old Jan 31, 2008 | 02:31 AM
  #167
J-Boogie's Avatar
J-Boogie is a decent person
thats correct
Old Jan 31, 2008 | 05:43 AM
  #168
da Liks's Avatar
da Liks is a decent person
i thought you knew that jeremy?
Old Jan 31, 2008 | 04:46 PM
  #169
owww oke
Yes i have the idle changed allready.
I thought there was a second cable somewhere?
Old Feb 4, 2008 | 04:15 PM
  #170
Sparks!'s Avatar
Sparks! is an unknown quantity at this point
I just done this mod last week, really easy and quick to do.
My bike ran like **** before hand and had a weak idle.
Admittedly I have also adjusted the throttle up as the cables were a bit stuck but now after doing the air box mod the bike is SO much better, it idles a LOT stronger and better, seems more responsive (at most times, did bog a little but playing with the stock idle seemed to improve it) and also seems a bit smoother as well... so glad I done this, thanks for the thread :YEAH
Old Feb 4, 2008 | 09:07 PM
  #171
01GSXR-600's Avatar
01GSXR-600 is an unknown quantity at this point
And will this mod also work on the 04 600RR? What do you do with the wire that hooks to the valve? unplug it and leave it?
Old Feb 5, 2008 | 05:30 AM
  #172
da Liks's Avatar
owww oke
haha ANOTHER cable?? :YEAH
Old Feb 7, 2008 | 07:12 AM
  #173
Joker001's Avatar
Joker001 is an unknown quantity at this point
will this Mod work the same on a 00 model F4???
or is it a waste of time on non-injected bikes?
Old Feb 7, 2008 | 02:34 PM
  #174
if your bike doesn't shut off right away when it is lying on it's side i would do the mod but if it shuts right off then your probably alright but most bikes stay running because the idle is turned up...
Old Feb 7, 2008 | 02:37 PM
  #175
never did one on an rr but you could leave it plugged in to fool the computer and just use a plastic t to hook all the hoses to ,or just unplug it and see how the bike runs
Old Feb 7, 2008 | 03:04 PM
  #176
Vetter's Avatar
Squid Extradoinaire
so wheres the diagram to do it. im gonna do this tonight. what do i need. the pics earlier in the thread are way to big.
Old Feb 7, 2008 | 03:29 PM
  #177
read this thread and if you don't understand how to do it by then just have some one else do it..lol
your just bypassing your air box......
Old Feb 7, 2008 | 03:57 PM
  #178
Vetter's Avatar
Squid Extradoinaire
so you jsut run the crank case vent tube into the exhasut instead of into the airbox... then cap the airbox?
Old Feb 7, 2008 | 04:01 PM
  #179
pretty much ,via the clean air valve...
Old Feb 7, 2008 | 07:37 PM
  #180
Joker001's Avatar
cheers mate, i appreciate the quick response. mod in progress now
