how to air box mod f4i
Old Oct 28, 2007 | 02:25 PM
  #61
Re: how to air box mod f4i
lol .
Old Oct 28, 2007 | 02:50 PM
  #62
Finally found some caps for the airbox. Going to get to work now.
Old Oct 28, 2007 | 03:03 PM
  #63
remember you may need to adjust stock idle cable to maximize the pull on idle after this mod
Old Oct 28, 2007 | 03:28 PM
  #64
****.. I knew that didn't seem right. 3/8" is way too small
Old Oct 28, 2007 | 03:31 PM
  #65
3/8 is big enough as far as flow and you could just use hose clamps to hold the hoses on
Old Oct 28, 2007 | 03:32 PM
  #66
as long as it's 3/8 inside diameter
Old Oct 28, 2007 | 03:45 PM
  #67
Beto's Avatar
Nags, 3/8 didnt seem big enough for me either...I used 1/2'' tee with clamps to be 100% sure
Old Oct 28, 2007 | 03:50 PM
  #68
that would work too......lol
Old Oct 28, 2007 | 04:22 PM
  #69
You know I don't roll like that.
Just went to 5 stores but finally found 5/8" fittings.
Old Oct 28, 2007 | 04:29 PM
  #70
as i was typing it i thought to my self nags is already on his way to the store to get the perfect fit....lol
Old Oct 28, 2007 | 04:36 PM
  #71
All done with the hoses. What do you do with the box that plugs into electric? Just unplug it altogether?
Old Oct 28, 2007 | 04:40 PM
  #72
DirtyToes's Avatar
DirtyToes is a decent person
i left em on...the only only holes i covered were the big ones. don't think ur supposed to do anything with the electric.
Old Oct 28, 2007 | 04:41 PM
  #73
So I leave that entire unit still plugged in?
  #74
DirtyToes's Avatar
more info please...i have the 2nd idle cable mod
wat should i set the idle at for the stock idle cable?
Old Oct 28, 2007 | 04:44 PM
  #75
DirtyToes's Avatar
juss to be sure, what "unit" are u talkin" about?
i just routed the t-fitter...and plugged where 3 and 4 used to go. thats it.
p.s. i'm juss tellin u wat i did....i would wait for others to replys be4 u finish everythin up and put the tank together.
  #76
The unit that you pulled all the lines from to put into the T fitting. That unit plugs into the harness
Old Oct 28, 2007 | 04:50 PM
  #77
Alright, I ditched it. No FI lights or anything
Old Oct 28, 2007 | 04:59 PM
  #78
i would leave it plugged in so the computer thinks it's still working but i have read that people have done it both ways....
i would start with the second cable all the way out so you can set your idle at 1000 rpm with the stock cable then turn your idle up to where you like it with the second cable and then try turning the first cable up a little bit at a time to see where it pulls best because the first cable adjust the air fuel mixture and it will effect how strong your idle pulls......
Old Oct 28, 2007 | 05:07 PM
  #79
DirtyToes's Avatar
ohh ya, i threw that piece out too.
and omr, i didn't get any FI lights from it being unplugged. just the same old 23 count but thats from takin off my smog
i'm gonna go practice in like an hour, i'll try wat u said with the idle.
Old Oct 28, 2007 | 05:16 PM
  #80
Alright, just finished up and took it for a test ride. Only did a few slow wheelies and they were just on throttle. Right off the bat I notice that I've lost a tiny bit of low end. Hopefully when I spend more time on it I'll notice a stronger idle though
