Fuel pump problem
Fuel pump problem
I'm having a problem with my fuel pump it occasionally does not click over and I have to turn my switch off and on a few times to get it to click over I switched out fuel pump relay thinking that was it but no luck ... Can anyone help ?:shrugg
Re: Fuel pump problem
Had the same problem once, as MikeM stated try to clean the switch it self, but if problem still persist you may want to check the fuel pump it self, it may need replacement.
