600rr fuel relay problem?? Anyone?
Ok so I threw my bike in the garage at the end of the fall last year. Never hooked it up to a charger or anything. Now that spring is near I rebuilt the whole bike. I had to charge it a little to get it to start and it ran fine at first. Now the bike will run and just shut itself down. Sometimes when you turn the key on the pump dosent prime. Could this be due to low battery voltage? Im gonna check that tonight. I just wanted to see if anyone else had the same issue. I dont want the damn thing killing on me mid wheelie you know
Re: 600rr fuel relay problem?? Anyone?
I had a problem with the relays going bad! They needed replacing and i havent had any other problems.
Also check your tip over sensor and it;s connected good!
the tip sensor is bypassed and the wires are connected good.
Im not by the bike now but ill let you guys know if i figure it out. till then post up if you have any ideas
99gixxxer750
Dec 16, 2012 09:12 AM
