fuel pump problem??
Old May 25, 2007 | 04:55 PM
StuntinJuiceBox's Avatar
StuntinJuiceBox is an unknown quantity at this point
fuel pump problem??
i got an 2001 f4i and the fuel pump jus stopped working outta know where, was runnin, stopped to take a break and it jus didnt work, i tested the pump its self, the fuel cut off relay, and the fuel pump relay and they all work, i also checked all the fuses that i know of, any body got any advice cause this **** is ****** pissing me off cause its nice as hell out and i cant ride!!
Old Jun 20, 2007 | 11:53 PM
"STANDALONE"'s Avatar
"STANDALONE" is a decent person
Re: fuel pump problem??
iam having the same problem. everything turns on its just not turning over. It turned on and then just died and now it just wont start up again. HELP, any and every advice tips and suggestions would be appreciated!!!
Old Jul 2, 2007 | 11:06 AM
DSC's Avatar
DSC
you guys figure this out yet? my fuel pump won't come on. i have checked engine kill, fuel cut, 30amp main, 10amp sub, if you put 12 volts to pump it will run. just stoped outta nowhere
Old Jul 2, 2007 | 11:33 AM
common causes for that:
tos jumper if you havent checked already
the single red wire from the battery directly to the fuel pump relay
check the wires goign into the ecu. a few times now ive seen the pink one rip from stress
Old Jul 2, 2007 | 12:22 PM
EZEC's Avatar
Embrace the Hate
last week i spent an hour on the side of the road beacuse my fuel pump cut out...turned out to be a bad ground.
if you have jumped the tos and checked everything else check the ecu
Old Jul 2, 2007 | 01:19 PM
-ChaOs-'s Avatar
Weeeee!!
-ChaOs- is a decent person
Make sure you check the ECU, the wires always break in there which will cause that issue seen it a hundred times. Oh ya and make sure if thats it and you repair it to put it in the right spot lmao
Old Jul 2, 2007 | 03:38 PM
DSC's Avatar
DSC
thanks guys im going back over everything
Old Jul 2, 2007 | 03:59 PM
DSC's Avatar
DSC
is there a set/color wire i should look for in particular on the ecu. mike says pink
freestylemotox
Jul 23, 2013 11:31 AM
johnnygixxer
May 24, 2013 01:31 AM
blayl
Apr 7, 2013 09:44 PM
BenRiley86
Feb 26, 2013 10:00 AM
Jeffknight27
Dec 3, 2012 10:55 PM
