12 help, bike problem.
Old May 8, 2003 | 11:04 AM
jay_9se7en3's Avatar
jay_9se7en3 is an unknown quantity at this point
Ok heres the problem. I have a 97 GSXR 600 with stock gearing. Everytime i try to clutch it at slow speed to 12 the bike blurbles, comes up a little at low RPM and comes back down. I originally thought it was my floats and i readjusted them (still a little off) but no improvement. First gear wheelies at higher speeds as well as 2nd and third are no problem. Could it be my gearing? Is it that I am trying to clutch a stock geared 600 up at like 5 mph to 12 the problem? I ordered new sprockets -2+3, is this going to help with the stumbling?
Old May 8, 2003 | 03:08 PM
PavementEater's Avatar
Gearing it down should help a lot, and put about 15 psi of air in your rear tire.
Old May 9, 2003 | 09:45 AM
Mine does that too. I just clutch it up higher from the start so I wont really need any power.
Old May 10, 2003 | 01:31 PM
Black_ops_1 is an unknown quantity at this point
Sounds like you are not hitting the power band yet. I goose the throttle a few times while clutched in to get the engines rotating mass going. I then bring it to about 4500rpm and controll the rpms as I let out the clutch controlled but quickly. The object is not to let the rpms drop too quickly untill the bike comes up. I know it sound weird and not easy to do, but it works.
Old May 10, 2003 | 03:58 PM
KrazyKris750's Avatar
KrazyKris750 is an unknown quantity at this point
I unfortunately don't 12've yet...but I think that the gearing will help alot
punchinghookers
May 21, 2013 02:17 PM
casey f2
Nov 1, 2012 04:12 PM
foxracinggirl
Feb 15, 2007 01:27 PM
LiL Momma
Feb 15, 2007 01:12 PM
DreamRyder
Detroit Street Ryders
26
Oct 12, 2002 10:28 AM
