fuel pump priming issues..
Old Feb 18, 2007 | 11:15 PM
inolen's Avatar
So today my bike started having some problems with the fuel pump not priming. The pump ran fine and never shut off or had any other problems while riding. But if I would turn the bike off, it wouldn't prime when I turned it back on sometimes. I jiggled the harness that the tip over sensor connects to and it started priming again sometimes. Once I got it to prime, I could ride around with no problems. None of the wires look frayed or messed up at all, any ideas on what it could be?
Old Feb 18, 2007 | 11:29 PM
martino's Avatar
wheres all the fat girls
martino is a decent person
Re: fuel pump priming issues..
so its bypassed?
Old Feb 18, 2007 | 11:34 PM
inolen's Avatar
Originally Posted by martino
so its bypassed?
Yea, just a piece of wire connecting the red/whi and ground. It's in there fine. I jiggled farther up on the harness and it just magically primed all of a sudden. But it could be completely unrelated.. I figured if my tipover was causing the problem my bike would shut off while riding it? I mean I'd literally pull up, bike running, turn it off, then turn it right back on and it wouldn't prime.
Old Feb 19, 2007 | 01:50 AM
Hajinomoto1's Avatar
Hajinomoto1 is an unknown quantity at this point
Hey Anthony,
Could it be a loose ground somewhere in the harness? Mine did the same thing when I ghetto rigged my acerbis headlight and the ground wire popped off. The only symthoms were that the lights on the speedo were all acting wierd (both signal indicator/highbeam lights stayed on)
Old Feb 19, 2007 | 01:59 AM
inolen's Avatar
Originally Posted by Hajinomoto1
Hey Anthony,
Hmm.. tomorrow I guess I'll tear it apart and look over the harness even closer (I looked at it today and couldn't find ****).
I don't know much about electrical stuff, is there an easy way to test for this?
Old Feb 19, 2007 | 04:03 AM
The F4i shop manual has a good trouble shooting section that I used to diagnose my electric problem. If you don't have it, you can DL at http://www.stephygee.com/.
Old Feb 19, 2007 | 09:24 AM
make sure your battery terminals are tight
Old Feb 19, 2007 | 12:02 PM
f4ibry's Avatar
u been huffin?
yo man i had this same problem , my tip was bypassed perfectly, but my harness had a broken wire in the sheathing, with undamaged outer sheathing, the only way i found it was by pullin on the wires and it just happend that i pulled on the bad one, which immediately snapped the outer sheathing....good luck, might wanna get a new harness cuz mousetrappin sucks some dick
Old Feb 19, 2007 | 12:21 PM
F4i fuel pump wont prime
Old Feb 19, 2007 | 04:31 PM
inolen's Avatar
So I found the problem, however, I'm still slightly confused by it.
The blue/orange wire and pink wire coming from my ignition had some bare area in the sheath and were touching.
The weird thing is that when they touched, it wouldn't shut the bike off. But if they were touching before I turned it on, the fuel pump would not prime. Any ideas?
Old Feb 19, 2007 | 05:58 PM
ct954's Avatar
ct954 is an unknown quantity at this point
My friend had the same thing happen. His 954 front end would rub the wires cause how close it came to the frame when he turned and wore though. If it the same you just have to re-route the wires.. Good luck.. Sucks stalling in a wheelie...
Old Mar 9, 2007 | 06:20 PM
stuntinatx's Avatar
stuntinatx is an unknown quantity at this point
my pump wasnt working either. just after reading all the post i checked everything then i realized i had a brand new ignition layiing around tried it and bam it worked.:YEAH :YEAH
Old Mar 9, 2007 | 06:26 PM
N/A's Avatar
N/A
Usually that happens b/c it sends an error to the computer and the computer kills the bike so you don't blow it up. The ECU is designed to cut out all power, etc whenever there is an overload or some sort of error (ie: two wires touching while the bike is running) But if the bike is already off and you turn the key on while the two wires are touching, the bike doesn't realize it's a break in the system... now obviously the pump won't prime but you'll at least get power.
Wheeliest's Avatar
Scrapes Elbow
that wire sends the ecu 7ish volts which tells ecuto prime the pump, if ecu gets any more / less it the computer says NO GO. i think after it primes and starts that wire signal doesn'tmeanshit any more.
Old Mar 11, 2007 | 12:46 AM
DBOUNCE1's Avatar
Hey Anthony,
what ground? cuz mine was running fine tuesdaynight and the only thing i have done since then is wire up my acerbis...and i did a sloppy *** job but it still works
Old Mar 11, 2007 | 09:17 PM
f4istunna's Avatar
f4istunna is an unknown quantity at this point
i went out to the lot today for the first time since last year and mine started doing the same thing. I havent changed anything since last year but i did notice when the bars are turned all the way the wires are kinda snug against the forks. Im going to tear into it tomorrow and see, gotta get it fixed suppssed to be near 60 next 2 days. Mine never died completely but did bog down 2 or 3 times while in wheelie today. My lights or anything dont come on when i turn the key on, would work every now and then, when i got home it quit completely lol glad it waited until then since i rode to the spot
Old Mar 12, 2007 | 02:57 PM
f4istunna's Avatar
found out mine had a burnt up connection on one of the ignition wires where the main harness plugs to it. Didnt see any bare wires anywhere. Anyone know what else could cause this? I dont really wash it so i dont think it got wet lol
big ben
Nov 10, 2013 06:16 PM
tie3278
Aug 30, 2013 10:22 AM
freestylemotox
Jul 23, 2013 11:31 AM
johnnygixxer
May 24, 2013 01:31 AM
Jeffknight27
Dec 3, 2012 10:55 PM
