need help with suspension setup for stuntbike
Old Apr 25, 2009 | 02:47 PM
thompson2oif's Avatar
thompson2oif is a decent person
i recently built a stuntbike out of an 01 gixer 750. i have it set up with a full front end from an 06 gsxr1000. forks, triples, wheel, and brakes. i need to know the best way to set up the front suspension for endos an slow wheelies. also need to know the same for the rear shock. how should i set the compression damping, rebound damping and preload???
Old Apr 28, 2009 | 01:21 AM
Dr_Rip_It's Avatar
control switcher
Dr_Rip_It will become famous soon enough
Re: need help with suspension setup for stuntbike
what made you set it up with a 1000 front end??
Old Apr 28, 2009 | 01:27 AM
krazykyle85's Avatar
krazykyle85 is a decent person
www.rg3suspension.com
they help me dial in all my suspension. check it out. you wont regret it.
Old Apr 28, 2009 | 01:25 PM
the origional forks and brakes on the 750 were bad and i had just parted out an 06 1000 so i used those parts to rebuild the front end on the stunt bike. would you say that was a good move when it comes to stuntin?????
Old Apr 28, 2009 | 01:33 PM
Bray's Avatar
Certified
if your rolling 500+
Old Apr 28, 2009 | 01:38 PM
i definatly dont need a complete fork and shock rebuild right now. i pretty much just need to know what preload, compression and rebound damping settings will make it easier to learn endos and slow freestyle stunts. any advice?
bobjoe
Aug 30, 2014 09:25 PM
suprarx787
Dec 26, 2013 09:36 PM
Brian94tt
Apr 12, 2013 07:40 PM
helipilot
May 6, 2003 11:06 AM
BTBubba
Dec 6, 2002 02:39 PM
