636 03' oil pressure problem
Re: 636 03' oil pressure problem
i fucked my motor like that
it was only half full of oil and it went down
the oil light came on and DIDNT go off
i asked some ppl here about it and they said it will be ok it stays on for a bit......... but let me say it started ticking and grinding before the light went off
so I went riding again today
same ****
crashed to the right
started it
leaned it to the left on the sidestand
nothing
did it again
nothing
waited
throttled up
it dissapeared
since I got nice weather I gonna abuse it as long as I can
then I will play with the clena air mod and deburping the oil filter
I also have a reversed style oil pickup.
it will rain-it will get done.
same ****
started it
nothing
did it again
nothing
waited
throttled up
it dissapeared
when i said leaning the bike on to the kick stand i forgot to say with the bike off , that will allow the oil to drain back into the sump in the oil pan quicker because when the bike is running the clutch basket is spinning the oil around so it takes longer for it to get back to the pan .....
the clean air mod wont change any thing in this situation but i still recommend doing it for a host of other reasons .....
same ****
started it
nothing
did it again
nothing
waited
throttled up
it dissapeared
same ****
started it
nothing
did it again
nothing
waited
throttled up
it dissapeared
This is Jerry the guy that Compton is talking about
I've had this problem, since day one. Anytime my bike goes to the cage on the right side, running or not it will loose oil pressure. You can lay it down on the cage and pick it right back up with the engine shut off and it will do this, or when you highside anything doesn't matter.
If I let it run it takes an insane amount of time to correct itself. Leaving it on the kickstand or putting it on the cage on the left does nothing, even leaving it for days!!
The only way it will work is loosening the oil filter up and crank it, runs for a second and oil comes out tighten it up and your good!
Same thing when the oil is changed, no pressure even if the filter is filled.
Been inside my pan too and don't see anyway it can get an airtrap but it does. overfilled underfilled doesn't matter.
And yes it only happens on some of the 636's... 2 out of the 8 people I personally know that rides them have these problems.
Any other ideas of a fix let me know I'll be the first to try it!
I always crank mine right after I pick it up. then after I'm sure it's not going to catch pressure I roll it over to the grass and crack it open. maybe thats the differance is I don't let it sit on the stand for a few seconds before starting it. I'll try it next time I ride.. trust me I'll def. highside sometime and put it on the right side.. lol
Anyways I'll post up how it does after next weekend!
not a 636, but if I drop my bike, even with it not runniogn, and I picked it up within 10 seconds
And I start it instaantly, it ALWAYS take 5-10 seconds to build pressure..
If I pay my bike over for 10 seconsd, pick it up, and wait 5 minutes to start it, it can take over 30 seconds to build pressure!
**** makes me nevous, already had my oil pump out twice, and myoil pan off 3-4 times!
Next time I'm gonna order a new pickup gasket, and install that and see if it gets any better..
btw used to run rotella 15-40 and figured that might be my problem, so now I'm on 10-30 super tech fully synthetic
reveresed oil pick up is a cut and welded back
pickup
this time the pickup is pointin backwards not forward
i will post some pictures of it later
pickup
kntmare181
Feb 14, 2013 01:00 AM
