how to air box mod f4i
Old Oct 28, 2007 | 05:17 PM
  #81
Re: how to air box mod f4i
remember you may need to adjust stock idle cable to maximize the pull on idle after this mod
i would leave it plugged in so the computer thinks it's still working but i have read that people have done it both ways....
i would start with the second cable all the way out so you can set your idle at 1000 rpm with the stock cable then turn your idle up to where you like it with the second cable and then try turning the first cable up a little bit at a time to see where it pulls best because the first cable adjust the air fuel mixture and it will effect how strong your idle pulls......
Originally Posted by nags
Alright, just finished up and took it for a test ride. Only did a few slow wheelies and they were just on throttle. Right off the bat I notice that I've lost a tiny bit of low end. Hopefully when I spend more time on it I'll notice a stronger idle though
Old Oct 28, 2007 | 05:19 PM
  #82
What?
Old Oct 28, 2007 | 05:24 PM
  #83
What?
play around with your stock idle cable becuase it will need to be adjusted after this mod......
start by setting it at 1000 rpms like i posted and the oooooooohhhhh **** this just go back and read..........
Old Oct 28, 2007 | 05:25 PM
  #84
and like i said i would leave the stock t plugged in so the comuter rhinks it's still working
Old Oct 28, 2007 | 05:26 PM
  #85
I adjust that **** everytime I get on my bike. You know better than that.
Old Oct 28, 2007 | 11:08 PM
  #86
DirtyToes's Avatar
DirtyToes is a decent person
just came back from the spot.
HOLY ******* DIFFERENCE...first, didn't touch the stock idle...didn't notice much difference...but then i took turned up the stock 2-3 turns....holy **** i love it!:YEAHthx guyz
offtopic but almost looped a ss, my awesome hb saved me at the last second. its hella
Old Nov 5, 2007 | 04:28 PM
  #87
BeLLiSSimO1's Avatar
BeLLiSSimO1 is an unknown quantity at this point
Thinkin of doin this, but anyone had any negitive long term effects from this mod?
Old Nov 5, 2007 | 04:33 PM
  #88
there are no long term side effects except you don't hydrolock and blow your motor....
Old Nov 5, 2007 | 04:49 PM
  #89
DSC's Avatar
DSC
only one i see is that you might actually get better
Old Nov 6, 2007 | 08:36 PM
  #90
fair enough:YEAH
Old Nov 7, 2007 | 02:36 PM
  #91
nomad's Avatar
nomad is an unknown quantity at this point
the guys that have done this mod, do you tape off the right side opening on the airbox or leave that open?
Old Nov 7, 2007 | 02:50 PM
  #92
one has nothing to do with the other..
tape it up and if it runs better then keep it covered if it doesn't then don,t
Old Nov 7, 2007 | 04:01 PM
  #93
nomad's Avatar
i wasnt sure, was just curious to see if anyone has done this and their results if it did affect it or not. sorry for any confusion.
Old Nov 7, 2007 | 04:05 PM
  #94
i know some f4i's run better on the street with it blocked off but i also know a bunch that don't so i think you should try it and see what works for your bike
Old Nov 7, 2007 | 05:04 PM
  #95
DSC's Avatar
DSC
is he talkin about the ram air tubes?
Old Nov 7, 2007 | 05:15 PM
  #96
yep .
Old Nov 7, 2007 | 05:23 PM
  #97
nomad's Avatar
i know some f4i's run better on the street with it blocked off but i also know a bunch that don't so i think you should try it and see what works for your bike[/quote]
the only mod i heard before this one was to tape off one side of the airbox to help out the low end, but i'll def. do this mod and try it with/without taping off one side like old man roger said and see what happens. thanx for advice.
Old Nov 7, 2007 | 05:30 PM
  #98
nomad's Avatar
hmmm. . i was tryin to use the quote thing, i'm not to good with this computer thing yet.
Old Nov 10, 2007 | 09:42 AM
  #99
So I rode for the first time last night since doing this and I think it does pull a bit harder on idle, but damn... It takes so much more to clutch the bike up now
Old Nov 10, 2007 | 09:48 AM
  #100
DSC's Avatar
DSC
you just need more gear nags
