yes another handbrake questions
Old Mar 2, 2006 | 04:02 PM
blurrymonster's Avatar
blurrymonster is an unknown quantity at this point
Has anyone ever just put a double banjo bolt on there existing rear master cylinder. And just tap on the new brake line there. Would this work ?
Old Mar 2, 2006 | 04:19 PM
Wheeliest's Avatar
Scrapes Elbow
Re: yes another handbrake questions
think people would bother making Fittings if it was that Easy?
It will Not Work, it'd push all the fluid right into the resi and blow the lid off lol
Old Mar 2, 2006 | 04:28 PM
yeah i didn't think so but i thought i would ask. thanks
Old Mar 2, 2006 | 04:33 PM
DBOUNCE1's Avatar
I thought of that a while ago
Old Mar 2, 2006 | 05:39 PM
-SKETCHY-'s Avatar
STUNTRIDE FRONTLINE
I Think You Can Tap In The Line At The Rear Caliper Though.
Old Mar 2, 2006 | 05:41 PM
*Tanus*'s Avatar
AZ's Finest!
+1
Old Mar 2, 2006 | 05:49 PM
DBOUNCE1's Avatar
will that work????
Old Mar 2, 2006 | 05:53 PM
-SKETCHY-'s Avatar
STUNTRIDE FRONTLINE
It Should.i Ordered A 1000rr Brake Master And Thats What I Plan On Doing.
Old Mar 2, 2006 | 05:54 PM
DBOUNCE1's Avatar
which master should i get? 929, 954, 1000rr???
Old Mar 2, 2006 | 06:42 PM
kj's Avatar
kj
I'm pretty sure that would do the same thing and just push the fluid back up into the rear resi and blow the top off...
think about what happens when you compress the pads by hand to take the caliper off.
If you can find the 1krr thats the ****.
Old Mar 2, 2006 | 06:48 PM
kj's Avatar
kj
If you could fab up an inline check valve for the rear pedal line, I think the double banjo at the caliper idea would work.
But thinking about it... then all the fluid would back up and end up w/ a stuck caliper... or it would just all go up the handbrake line..
just thinkin aloud.
My save your lunch money and get fullthrottle setup... it works sweeeet and once you bolt it up and bleed it you can just forget about it.
Old Mar 3, 2006 | 08:27 AM
-SKETCHY-'s Avatar
STUNTRIDE FRONTLINE
Gonna Try It Anyway.if It Doesn't Work I Will Order That Junction Box Master Thingy From Fullthrottleinc.com
Old Mar 3, 2006 | 10:23 AM
Wheeliest's Avatar
Scrapes Elbow
take a rear M/c appart, its simple like 3 parts and you will learn how they work alot better..
zeus_r6
Aug 23, 2014 04:11 PM
fergyfresh
Nov 9, 2013 07:13 AM
Beastin4shot
Jun 17, 2013 07:50 PM
Tough Luck
Jan 9, 2013 02:37 PM
BVRider1
Ronin Riders
Dec 1, 2002 02:12 PM
