900RR fuel problems
Old Oct 2, 2003 | 06:07 PM
E-DUB OM's Avatar
AGGRESSION!
E-DUB OM is a decent person
900RR fuel problems
My 99 900RR bogs like a ***** when there is not a full tank in it. I mean filled to the brim. The thing that sucks now is my tank is mashed like crazy and it holds alot less fuel so it is bogging all the time. I tried swapping tanks and fuel pumps and it still did it. What in the hell causes this. Is there a way to fix it. I need to figure this out because I am tired of bogging and slamming down in slow wheelies.
Old Oct 2, 2003 | 07:43 PM
Jay Carnes's Avatar
I Have Too Much Free Time
my 98 did that. even when it went down to 3/4 full it'd studder & come down. I just kept a gas can w/ me & kept that ***** full.
Partially the reason i just went fuel inected. that bitch is in reserve & still idles on the 12 bar. beautiful thing.
Old Oct 2, 2003 | 07:57 PM
BigBalla's Avatar
Re: 900RR fuel problems
what fuel pump did you use?
Old Oct 2, 2003 | 08:13 PM
E-DUB OM's Avatar
AGGRESSION!
I used a 99 fuel pump and a 96 fuel pump. Both of them did the same thing. Is there a way to keep it from doing this? It is driving me crazy. It is bogging all the time now. Hard to be consistent with a bike that is choking its brains out.
Old Oct 2, 2003 | 09:39 PM
DLISH's Avatar
u sure its not a float hieght issue?
Old Oct 3, 2003 | 01:01 AM
thewibb's Avatar
thewibb is an unknown quantity at this point
there is no pump on the 96'??? Vacuum fuel valve...
Old Oct 3, 2003 | 01:44 AM
JackassRR's Avatar
If you are tryin a pre 96 fuel pump..it will not work. The bike floods out after riding a 12 for 30' and sputters. Only other thing is cut the brass tube off the petcock, remove the tank filter and install an inline filter.
Old Oct 3, 2003 | 06:07 AM
Manny's Avatar
Manny is an unknown quantity at this point
Buy A GSX-R 1000 Sucker.
Old Oct 3, 2003 | 06:21 AM
J-Hook's Avatar
HoOk
J-Hook is an unknown quantity at this point
why? so hecan gear it down 2... and up 5... and still not notice a difference?
Old Oct 3, 2003 | 12:34 PM
Lb3's Avatar
Lb3
Has anyone done or thought about throwing the FI system out of a honda 919 motor on a 900rr? I was thinkin how much I would like to get a 900rr but I just cant do it cause I hate carbed bikes and my friend who is a honda mechanic suggested swapping the harness and carbs for a harness and throttlebodies from a 919... Sounds like a good idea to me. The ultimate bike..
Old Oct 6, 2003 | 08:06 PM
E-DUB OM's Avatar
AGGRESSION!
Man this **** is killin me!!!! How in the hell am I supposed to get my super slow **** on lock when the back is boggin like ****???? There has to be some wya to keep it from bogging? ANyone????? Does the inline fuel filter work? Somebody please help a BRUH out
Old Oct 6, 2003 | 08:47 PM
BigBalla's Avatar
removing the sock filter and using an in-line filter does help, but if your tanks bashed bad, then its gonna have to be full to the TOP!
Jackass: i still havent been able to try a pre- 96 fuel pump, but why would it flood? 900's bog from lack of fuel. your sayin that a fuel pump is not gonna solve this?
Old Oct 6, 2003 | 10:42 PM
E-DUB OM's Avatar
AGGRESSION!
I hear you but theres gotta be a way to keep it from doing this. Does anyone have a way that works? THere are soooo many people out there that ride 900RR with mashed tanks and they seem to be doing fine. What the hell? Why does mine bog like a *****?????
Old Oct 7, 2003 | 05:17 AM
E-DUB OM's Avatar
AGGRESSION!
Im just going to have to start trying new things to see if I can solve this shiiiiiiiiitttttttttt
Old Oct 7, 2003 | 12:36 PM
JackassRR's Avatar
The fuel pump gives it too much fuel and it basically floods it. I rode with the pump for about 10 min then took it off. The only thing I didn't try was a non-vacuum assisted petcock with the pump..i used the 98 petcock. From what I hear it wont matter..if still floods
Old Oct 7, 2003 | 12:55 PM
JAVIER's Avatar
JAVIER is an unknown quantity at this point
I HAD THE SAME PROBLEM DO THE INLINE FUEL FILTER.TAKE THE PECKOC OF AND TAKE THE STOCK FILTER OF AND THE LITTLE PICE OFF PIPE.THE PISE OF PIPE COME OFF WITH PLIYERS.PUT THE PECKOC BACK ON.YOU NEEN TO GET YOUR CARBS SINKT.IF YOU DONT GET YOUR CARBS SIKT YOUR PROBLEM IS NOT GOING TO GO AWAY
freestylemotox
Jul 23, 2013 11:31 AM
Ro100Proof
Mar 19, 2013 02:25 PM
BenRiley86
Feb 26, 2013 10:00 AM
Ro100Proof
Feb 23, 2013 12:17 PM
Jeffknight27
Dec 3, 2012 10:55 PM
