how to fix the fuel pump issue after droping r6 hard
Re: how to fix the fuel pump issue after droping r6 hard
oh and i forgot to mention that there will most likely be a little white washer looking thing and an o-ring somewhere in your gas tank. locate these 2 items and before you put the pump back together make sure you put the o-ring on first(top side of the pump) then clip on the white plastic washer that holds the o-ring in place.
hey mitsuman will that situation throw a code? cause i pancaked my r6 on the left and now it wont start. cant figure my **** out. im going to do what you did over this weekend.
damn, yall must be crashing SUPER hard. i have never had that problem, even when i was a squid, and flipped my bike down the freeway.
my falls nowadays are alot softer, and ****... no matter how many times i have dropped it. i never had a separated fuel pump.
but good work nonetheless.... great when people share information for prevenative measures.
99gixxxer750
Dec 16, 2012 09:12 AM
