chain links
Old Jun 11, 2004 | 11:03 PM
c0rey's Avatar
c0rey is an unknown quantity at this point
chain links
can you take links out of your stock 50 chain? and if so how do u do it...........thanks c0rey
Old Jun 12, 2004 | 07:01 AM
Re: chain links
grind a rivet down with a bench grinder and use a punch to knock it out.
Old Jun 12, 2004 | 09:08 PM
Xidium's Avatar
Re: chain links
You can also Grind a side of one in half and pull it out.
Old Jun 12, 2004 | 10:01 PM
c0rey's Avatar
Re: chain links
great, thanks guys ill be doing this tonight. I just bought a 35 tooth sprocket and you have to remove some links iono how many yet but ill keep anyone posted c0rey
Old Jun 12, 2004 | 10:28 PM
Z50NATIONALS's Avatar
Re: chain links
hehehehe i use a die grinder and a chain popper neat lil tool
heres the way i do it so i never fubar a chain and need two masterlinks
put it all back together roll it on the rear sproket do the overlap
mark the chain if you have to take it off and over to the grinder
to long is ok to short and you are fubared
hope this helps explain it better
Name:	rear sproket overlap.jpg
Last edited by Z50NATIONALS; Jun 12, 2004 at 10:50 PM. Reason: adding illustrations
Old Jun 12, 2004 | 10:33 PM
Xidium's Avatar
Re: chain links
Sometimes I dont understand you Z50. I got what your saying, just takes some serious thinking.
Old Jun 12, 2004 | 10:36 PM
Re: chain links
yeah im hip my bad , im not much at typin about it
but i could show you in about 3 minutes start to finish
Old Jun 13, 2004 | 11:40 PM
nappers_SD's Avatar
nappers_SD is an unknown quantity at this point
Re: chain links
I just use a dremel to grind down the pin that needs to come out. Grind down both sides all the way down. Set the chain on a couple of blocks and place the pin that needs to come out in between so you can punch it out. Sometimes it takes a good swing of the hammer, but I'e never had a problem doing it this way and it's done in minutes. Good luck!
Old Jun 16, 2004 | 06:56 PM
Re: chain links
oh one other thing
cut it at the link not at the plate
that should be obviuos but sometimes isnt
Swavey
Jun 19, 2013 11:44 PM
07BlackBeast
May 3, 2013 07:46 AM
HiC.d.OuT
Apr 10, 2013 05:38 PM
EasyDubsIt
Mar 28, 2013 02:53 PM
Clint Ewing
Oct 11, 2012 01:31 PM
