High flow air filters
Anybody know of some good ones? Are those cone ones better or is the extra air just warm? What if you added to the hose and had the cone sticking outside the bikes plastic?
Re: High flow air filters
stock is usually best
for a stk motor i guess thats what you have
buy a k&n with a built in velocity stack if you run an aftermarket filter
help the air
pods are really for top end stuff so i guess it depends on what your doing with it stunting with a stock motor id run a stk air box
still air look it up if, it didnt need the air box honda wouldnt put it on there
im currently trying to build a stk airbox from a mr50 airbox for my z motor
id rather have the box than a wide open pod
help the air
I've got a K&N on mine.. its pimp
