Takegawa 88cc Bore Kit with 18mm Carb. Whos actually runs right
wow thanks HB . no can do though, the 20 runs much better for me. imprezawd can back me up on that. maybe in different climates or elevations the 18 would work but not for me, or anyone i've talked to. my fiddy runs strong as hell now, i'd recommend the pc20 to anyone.
B
B
I have the 18 with my kit, not even my bike shop could get it running right. I have played & played with it & finally got it running OK. But only prob I carnt fix is it runs very lean down low untill very hot, then once hot it runs very rich. I have tried & tried so I guess I have kinda learned to live with it.
Apart from prob, I think this kit is great for my needs, best money I have spent....
Originally posted by hb five0 rider
well what jet are you running? run the 85 or 82, it will run great. i dont see how you are all having problems with the 18, i have never heard of anyone having a problem with the 18.
If I move the clip up 1 the fiddy wont even start, if I move it down 1 it boggs & splutters & BBBWAAAAAAAAAA..
weedracer that's exactly what i did, i knew that'd work fine b/c i had run that setup on my bike in the past. i just adjusted the needle and airscrew and it's fine now. we're putting on imprezawd's ported head tonight and we'll see if we can't tune the 18 to that.
B
B
Are u NUTS!!!!!!!!!!! I paid for that CARB i am using it !!!!!!
I rode my boys with a carb and mine with the OEM style carb and nothing compared to my boys. NOTHING ! If you are not running a carb you are loosing out on sooo much power..
I still think for STREET stunting the big bore kit and carb is a waste of money !! Way to twitchy
yeah whatever mr. 1/4 turn throttle... that's why you got off my 88 and said you never wanted to ride your piece of **** again! once i have the fiddy geared properly the top speed should (hopefully) be something like 45+, but i'll still be able to pull wheelies (and whoop yo ***) w/ ease.
B
B
Originally posted by weedracer
[B] get rid of the 18, put the stock carb and air filter and pipe back on, then your bike will be fine [B]
Originally posted by kiwi50
I am to the point of being totally confused about which was 2 go. Im pi$$ed that I carnt quite gut it running perfect, but im not gonna let it beat me. I will try & try till I get it right. Dont see the point of putting standerd stuff back on when I shelled out for this carb,filter & exhaust..
Now if your like me and can`t leave well enough alone. You add high flow filter, rev box, and a pipe. Spend hours jetting it and now you have bike with a little more topend and very little bottom end compared to what you started out with. hhhmm must need a bigger carb to compensate for all that air flow. Ok 20mm carb is on. The bike bogs and hesitates like a **** then pulls unbelievably hard on the topend. That bog must be from the fact that I`m trying to force all this gas and air through an intake port in the cylinder head the size of my pinky finger. Add a highflow cylinder head and the bike runs clean again. No bogs and tons of power throughout the entire rpm range.
The moral of the story is all of your aftermarket parts must work together to have smooth running engine. Don`t try and compensate. If you going to make part of the engine highflow, make the whole thing highflow. This is just based on my own experiance, But I would save $200 and buy the kitaco light bore over the takegawa s-stage. Then when I was ready to double the power again get a cylinder head and a carb that is bigger than the one that comes with the s-stage.
Andre 1000
01-30-2013 08:12 PM
