Clutch assembly help PLZ!
Old Sep 4, 2003 | 04:57 PM
RCFiddy1's Avatar
RCFiddy1 is an unknown quantity at this point
Question Clutch assembly help PLZ!
What up every1? Newbie here, got a question I'm hoping someone can answer. My neighbor's son sunk his fiddy in a big H2O hole and ended up cracking the cylinder. I bought it really cheap & I'm trying to put it back together but didn't get to see it being disassembled. I figured everything out but one thing. The right side engine case cover, underneath is a spring, two plates that roll on bearings, and a lever. I figure the lever goes on the splined shift shaft but not sure what position it should be in, as in reference to the face of a clock. And the two plates and the spring, no freakin clue. Can't find a manual or breakdown anywhere so I'm keeping my fingers crossed that someone here can help. BTW it's a 03 fiddy.
Old Sep 4, 2003 | 08:13 PM
aim that bitch right for the center of that bearing on the clutch assembly. once that is assembled and the side cover is on... loosen the locknut on the sidecover,turn the screw in a bit and then turn it out until resistance is felt, then from there turn it back in 1/8 to 1/4 of a turn. then tigfhten the locknut and u should be all set. hope this helps. good luck.
C-Dub
May 8, 2018 12:52 AM
Apr 5, 2017 10:29 AM
SlitZ
May 6, 2013 06:24 PM
Brian94tt
Apr 12, 2013 07:40 PM
nsschwenk
Oct 16, 2012 02:10 PM
