Will a Stock xr70 cylinder and piston fit on a fiddy
Old Sep 4, 2003 | 03:22 PM
ponchoman's Avatar
ponchoman is an unknown quantity at this point
I was wonderin if any of u peeps know if a stock xr 70 cylinder and piston will bolt up to a fiddy. Think it would have much of a gain? Thanks
Old Sep 4, 2003 | 04:14 PM
BLOWNSVT's Avatar
BLOWNSVT is an unknown quantity at this point
The 70 piston won`t work with the 50 head. 50 heads require flat top pistons. The 70 head requires domed pistons.
Old Sep 4, 2003 | 08:18 PM
if u use a 70 head u should have no problems. the old 70 heads have bigger valves than the fiddys but smaller lift cams. so its a toss up unless u get a aftermarket 70 cam or maybe the newer xr70 heads have bigger cams.
xxSHANNONxx
Jan 22, 2013 10:57 PM
Tough Luck
Jan 9, 2013 02:37 PM
Stefanenyce808
Dec 19, 2012 09:07 PM
KpeckR6
Dec 19, 2012 08:38 PM
