50 Wont Start
Old Nov 4, 2007 | 02:14 AM
bigkapp's Avatar
bigkapp is a decent person
50 Wont Start
brought up into my apartment... did a few mods(bars, forks, plastics, pegs) no engine work.. its been sittin around for a couple weeks, took it out today and the thing wont start... took of carb and cleaned it, took out airbox, cant figure out why the hell it wont start????? come on you guys know everything, any ideas
Old Nov 4, 2007 | 03:19 AM
Sgt.Stud's Avatar
Sgt.Stud is a decent person
Re: 50 Wont Start
there is probably a kink in the ignition hose where the ignition molecules flow through to the flux capacitor. Also check your piston return springs, they may be going soft
Old Nov 4, 2007 | 07:49 AM
onewheelneil's Avatar
onewheelneil is an unknown quantity at this point
Re: 50 Wont Start
yep,you beat me to it! That was the problem with mine,to fix it so it won't happen again just wiggle the wires for the turn signals and repack the muffler with sand and gatorade.....you will never have a problem with it again
Old Nov 4, 2007 | 10:23 AM
Reckless01's Avatar
Yea...I got that!
Reckless01 is a decent person
Re: 50 Wont Start
not to break up the bs but did you see if you hooked the run/stop switch wires when you put the bars back on...Also hit it with starting fluid t see if it will start, if it don't then you may have an ign problem! maybe just pull the plug and see if there is any fire!
Old Nov 4, 2007 | 03:46 PM
Sgt.Stud's Avatar
Re: 50 Wont Start
your no fun
Old Nov 4, 2007 | 04:32 PM
bigkapp's Avatar
Re: 50 Wont Start
thanks bro i will check it out... these guys have too much fun..
Old Nov 4, 2007 | 09:23 PM
xr50s4life's Avatar
xr50s4life is an unknown quantity at this point
Re: 50 Wont Start
take off your spark plug and hold it next to the head and kick it. your checking for a spark if you got that you know its not your ignition. check all ground wires make sure there attached to the frame. clean your carb with b 12 carb cleaner and use compressed air in the mainjet. also try new gas or starting fluid as said above^^.
Old Nov 4, 2007 | 10:31 PM
chpsk8er630's Avatar
chpsk8er630 is an unknown quantity at this point
Re: 50 Wont Start
YOu remember to turn your key on?
Old Nov 4, 2007 | 11:54 PM
bigkapp's Avatar
Re: 50 Wont Start
yea sorry buddy, its nothin like that... yea imma just get a new spark plug tomorrow, and if that dont work clean the carb and the other things said...
Old Dec 10, 2007 | 07:22 PM
Yamahas4Life's Avatar
Yamahas4Life is a decent person
Re: 50 Wont Start
Take out your plug and sand it a lil bit.
Sometimes mine starts funny or runs rough.
I can pull out that plug and sand it and it fires right up.
jeeper5usa
Jul 9, 2013 10:04 PM
knowlzy0791
May 21, 2013 12:46 PM
knowlzy0791
Apr 13, 2013 07:32 PM
BenRiley86
Feb 26, 2013 10:00 AM
