air box mods?
Old May 27, 2005 | 04:04 AM
WAX-AZZ is an unknown quantity at this point
air box mods?
what kind of mods should i do to my stock air box to make it best possible?
Old May 27, 2005 | 07:07 AM
notastunta's Avatar
notastunta is an unknown quantity at this point
Re: air box mods?
www.50mods.com
Old May 29, 2005 | 01:14 PM
Z50NATIONALS's Avatar
Re: air box mods?
you should do no mods to the air box or the pipe
https://www.stuntlife.com/forums/sho...d.php?t=127047
Old May 30, 2005 | 01:12 AM
Re: air box mods?
lets if i understand correctly:
xr70 carb, intake and airbox on a stock 50 is the best light tuning? sounds like itll work, anything else need to be done??
Old Jun 1, 2005 | 07:06 PM
Re: air box mods?
ride the dog **** out of it
Old Jun 2, 2005 | 05:23 AM
Re: air box mods?
ohh yes it will be done
Old Jun 3, 2005 | 09:25 AM
Re: air box mods?
BTW. what sizes jets should i get with that xr70 carb? gotta be rejettet since its jettet for a 70cc right?
Old Jun 4, 2005 | 07:32 PM
Re: air box mods?
none
bolt it on and ride it
Old Jun 5, 2005 | 05:41 AM
Re: air box mods?
none
thanks again Z50
Old Jun 6, 2005 | 04:29 PM
Re: air box mods?
no prob enjoy
Old Jun 10, 2005 | 10:08 PM
fiddy rida is an unknown quantity at this point
Re: air box mods?
You could always go with the cheap way of modifying your air box like i did...take off the air box and put up a lil bracket to hold the stock filter in and then drop the pin down a notch and mess around with idle a little and you got a lil more power for free.
Old Jun 23, 2005 | 11:45 PM
melloyello's Avatar
melloyello is an unknown quantity at this point
Re: air box mods?
I recently purchased a xr70 carb and intake and it is not a direct bolt on. I had to replace the cable which luckily came w/ the used carb. You will have to use an aftermarket air filter or the stock 70 airbox which luckily came w/ the carb. I also had to cut the intake in two, turn it slightly, and weld it back together b/c the intake would not sit flush w/ the head b/c the throttle cable was hitting the frame. I also recommend that you port the head to match the intake or you are just wasting your time b/c the intake port for the 70 is a lot bigger than the port on the head. Just my .02
Old Jun 24, 2005 | 04:13 AM
Re: air box mods?
nice of you to tell so we know how does it run??
Old Jun 24, 2005 | 08:50 PM
melloyello's Avatar
Re: air box mods?
Had to clean up the weld today at work. Will probably mount it again on Monday and make any adjustments necessary and let you know. I have a feeling the low end response is not going to be what it used to but we will see.
Old Jun 24, 2005 | 10:48 PM
Re: air box mods?
you have to use the new 70 intake not the old one
mine bolted right up.... runs sweet u do have to cut and turn about
6 degrees on the older ones
Old Jul 24, 2005 | 03:52 PM
monsterminibike's Avatar
monsterminibike is an unknown quantity at this point
Re: air box mods?
http://www.starboyz.com/vboard/showt...threadid=15712
StarBoyz Forums - bought crf 50
Old Jul 24, 2005 | 10:30 PM
randomjibrish's Avatar
randomjibrish is an unknown quantity at this point
Re: air box mods?
http://www.ministothemax.com/hop_ups_airboxmods.htm
Clutch n' Chris
May 23, 2013 05:06 PM
Criscone24
Apr 16, 2013 05:29 AM
xxSHANNONxx
Jan 22, 2013 10:57 PM
njstunt855
Dec 18, 2012 12:43 PM
StreetRacr 67
Oct 20, 2002 02:23 PM
