clutch adjuster nut thingy question...
Old Dec 14, 2004 | 07:16 PM
yzfrone's Avatar
yzfrone is an unknown quantity at this point
how many turns do you guys have it (out) for a stock clutch...
every since i played with mine it doesnt feel right!
help
Old Dec 14, 2004 | 09:04 PM
Re: clutch adjuster nut thingy question...
that will depend on how worn the clutch is.
Old Dec 14, 2004 | 10:16 PM
yzfrone's Avatar
its okay...moderate...
so what do you think fab? how do you adjust this thing?
Old Dec 15, 2004 | 09:02 AM
thanx for the idea. i need to make a sticky about this. ok, heres what u do..
start the bike and let it idle in 1st gear. loosen the jam nut and turn the screw counter clockwise untill the bike starts to roll. at that point, turn the screw clockwise about a quarter turn and lock it down. the easy way to test this is to ride the bike in any gear. while riding, slowly lift up on the shifter. noticing when the clutch starts to slip. the end of the shifter should be moved about 1/2" to 3/4" right when it starts slipping. good luck
gixxeray
Jul 15, 2013 12:19 AM
03-636
Jun 26, 2013 04:59 PM
SlitZ
May 6, 2013 06:24 PM
Brian94tt
Apr 12, 2013 07:40 PM
Napkin Legend
Feb 27, 2013 09:56 AM
