Do I need a high flow oil pump?
Old May 31, 2004 | 06:39 AM
MiniMikeR1's Avatar
MiniMikeR1 is an unknown quantity at this point
Re: Do I need a high flow oil pump?
Originally Posted by imprezawd
The Takagawa Oil Pump comes with a Drill bit included. ! All i know is you should take a stud out so you can drill out that hole. Those 4 long gold shafts that hold the bore and head. You will need to take the one out near the hole you drill. VERY EASY!!! This is my 2nd bore kit and kitaco is the ****. I had a takagwa before and presonally like the piston and the finish of the kitaco.
Oil Pump is a good investment. !
the Kitaco is the first one i've heard of that didn't require major carb tweaking and other mods to run properly. i did the simple 88 Kitaco kit on my fiddy the other day. it rips on the road and in the bush and it only took a minute or so to mess with the stock carb to richen it up a little. the kit is really cheap and i'd recommend it to anyone and u can always add on later (big head, carb........)
swtorcredits
Apr 29, 2021 06:15 AM
Tony MPZ
Jan 14, 2016 01:08 AM
SlitZ
May 6, 2013 06:24 PM
kchad917
May 2, 2013 07:20 AM
yambike
Apr 22, 2003 11:18 AM
