Clutch Problem. Please help?
Old Jul 23, 2009 | 05:28 PM
NovaMan's Avatar
NovaMan is an unknown quantity at this point
K, So i replaced my Clutch friction disk's and springs. Got everything back together to relise that my throw out that connects to the clutch cable which in turn pushes on a spiral rod (just to clear that up) isnt engaging. No big deal, backed out the springs evenly making sure the spiral rod slides freely inside untill the throwout was touching. Button'ed everything back up. Put it in gear, pulled in the clutch and it doesnt take it outa gear. Ive adjusted everything i can think of adjusting to get it to throw out. And after about 5 times re-assembling the clutch cover im stumped....
Bike is a '94 Honda F2 btw. I assmebled everything just as it came apart as far as the disk's and basket go. Whats the deal? I gotta ride!
Old Jul 23, 2009 | 05:57 PM
Re: Clutch Problem. Please help?
did you soak the friction disks in oil before installing them ?
Old Jul 23, 2009 | 06:05 PM
NovaMan's Avatar
yes sir. nothing like a small headache to ruin the only 80 degree weather were going to see here all summer haha.
Old Jul 23, 2009 | 06:10 PM
hhmm i would have bet that was your problem , well im no help here then ..
i assume you adjusted the cable properly ?
i know thats a dumb question but i have seen some people pull out hair and come to find out it was a simple adjustment
Old Jul 23, 2009 | 06:28 PM
serious's Avatar
it is what it is
serious is an unknown quantity at this point
did you also change the steels or just the friction plates?
Old Jul 23, 2009 | 06:41 PM
NovaMan's Avatar
Just the friction plates. But Now that i have completely ripped everything apart again Ive come to notice that one of the very first steel plates I took off is severly warped and bent... How I did not notice this the first time when i re-assembled it i dunno. Or could this have happened from over tightening something? its just the one steel plate. all the others are fine.
Old Jul 23, 2009 | 06:45 PM
serious's Avatar
it is what it is
bingo. I had a funny feeling that was it. at least you didn't burn your brand new friction plates. new steels and you should be good. too bad you had to take it apart 5 times.
Old Jul 23, 2009 | 06:48 PM
serious's Avatar
it is what it is
i would take a real good look at the condition of all the other steels. I reuse the ones that are not chipped around the edges or discolored. If it's questionable, i'd replace it. Yeah, usually only one or two get a real beating and get warped.
Old Jul 23, 2009 | 06:55 PM
NovaMan's Avatar
Just ordered new ones and are on the way 36 bux! I love having a small sponsor haha.
Oh and this one be a good time to mention... Stunted the F2 for 4 years now (summers) and this is the first clutch repair its had to have (lost second gear pretty much haha) RIDE HONDA! I will also mention that my bikes got close to 45,000+ miles Lovin it.
Old Jul 23, 2009 | 07:53 PM
serious's Avatar
it is what it is
Hondas do indeed rock. I was not even knowing until i got one. Although, my 06 636 has over 100,000 miles and I still ride it to work.
freestylemotox
Jul 23, 2013 11:31 AM
caper
Dec 19, 2012 02:12 PM
Teamsquiddly
Jan 24, 2003 11:55 AM
cbr954junky
Core6
Jan 21, 2003 12:08 PM
