636 shifting problem
Old Oct 28, 2008 | 10:07 PM
DerekS's Avatar
DerekS is an unknown quantity at this point
I seem to be fixing my 636 more than im riding it.
I was in the lot tonight, I was in mid first gear and shifted into second. Rode in second for a couple feet and than it made kind of a clunking noise and kicked it out of second into neutral. Thought my chain broke, so I stopped and everything seemed fine. Started riding and shifting up or down into anygear(including neutral), its almost impossible to shift. The shift lever is hard as a rock.
The lever and linkage are straight. I don't think its going to be a shift fork because it's happening in every gear, and since than what little I rode it it didn't pop out of gear.
Any help/suggestions would be great,
Thanks in advance
Old Oct 30, 2008 | 03:03 PM
Suicidal Antics's Avatar
Suicidal Antics is an unknown quantity at this point
Re: 636 shifting problem
sounds like your gonna have to pop off the clutch cover, and check stuff out. Check the shift star, and see if its still in decent shape, and the pawl that rolls on it.
my 636 has jumped into nuetral 5 or 6 times since ive owned it...once while i was jumping to seatstander...threw me over the bars, and ran my **** over
Old Oct 30, 2008 | 08:07 PM
ToKwik's Avatar
ToKwik is an unknown quantity at this point
Don't rule out a fork just because it does it through all the gears.
The 636 has 3 shift forks that ride along a "shift drum". The shift forks follow the groves of the shift drum and in turn select the input and output gears.
So its possible that a single bent shift fork would cause the whole transmission to drag and not interlock properly.
Hope that helps some.
I can get more detailed if you think that is the problem. Time consuming, but not overly difficult to change out transmission components.
Old Nov 3, 2008 | 02:23 PM
REDBALLS302's Avatar
stanky leg
REDBALLS302 is a decent person
go with what he saiD^^^^^^^^^^ probably the shift forks......stop stomping on your shifter!!!!!!!!!!!!!!
Old Nov 3, 2008 | 02:29 PM
-SKETCHY-'s Avatar
STUNTRIDE FRONTLINE
what he said
Old Nov 3, 2008 | 02:48 PM
ToKwik's Avatar
Forgot all about this thread. Damn lack of short term memory cells.
Schaff, did you ever find out anything?
Old Nov 3, 2008 | 09:18 PM
DerekS's Avatar
Not really,
I brought the bike to work the next day and was going to have the tech look at.
Shifted completely fine, as if nothing was wrong. I've ridin it a couple days in the lot now and had no problem since.
There's not much of the season left here, so I will probly rip into it in a week or 2 and make sure everything looks good. I'll definitly check out the shift forks though when I do.
WARstunter
Apr 14, 2014 11:55 PM
knowlzy0791
Jul 26, 2013 11:56 AM
caper
Dec 19, 2012 02:12 PM
greenhornet347
Oct 15, 2012 02:26 PM
crazeinc
Dec 5, 2002 10:31 PM
