need help with a clutch fix, the cheap way....
Old Jul 21, 2006 | 05:55 PM
suzukibobby's Avatar
suzukibobby is an unknown quantity at this point
So i have a 93 900rr and my clutch is slipping lightly when i am just riding but its to the point that i can't clutch a wheelie any more. The motor just revs up and i go nowhere. I am told that i can just replace the friction plates and call it a day. What do you guys do? do you think i need to replace more? like the steel plates or springs? That **** just costs way too much.
Old Jul 21, 2006 | 06:04 PM
MikeOnTheBike's Avatar
WWW.IDOLRIDERS.COM
MikeOnTheBike is an unknown quantity at this point
Re: need help with a clutch fix, the cheap way....
grind the steels with a sanding pad on the grinder, adds life to a f'd up clutch, or buy my 900 it's got a brand new clutch
Old Jul 21, 2006 | 06:17 PM
jcrojas's Avatar
jcrojas is an unknown quantity at this point
Not to question your knowledge, but have you adjusted the clutch (or had a knowledgable friend adjust it)?
Old Jul 21, 2006 | 06:29 PM
no, i don't know anything about bike clutches. I do work on cars though so im not an idiot when it comes to repairs. I adjusted the lever, its set right. Can you internally adjust the clutch?
Old Jul 21, 2006 | 07:34 PM
Idle Hands's Avatar
Idle Hands is an unknown quantity at this point
an nice 4-600grit sand on the steels (as long as there not warped) is a easy fix to the glazing, you probably are going to need the frictions as well as new springs. I actually went with a set of springs from another bike (triumph daytona). they were the same diameter just a bit stiffer. worked much beter than new stockers. before you replace anything take a look at the last friction plate, the smaller one, I bet you just shattered it, happens all the time on the 9hundo's. good luck.
stuntin'_cbr
Nov 20, 2024 11:08 PM
SlitZ
May 6, 2013 06:24 PM
Napkin Legend
Feb 27, 2013 09:56 AM
KawiKid76
Dec 20, 2012 09:57 PM
njstunt855
Dec 18, 2012 12:43 PM
