f3 rear brake problem..need help asap
Old Apr 19, 2006 | 01:09 PM
Bobby@BullyDog's Avatar
Bobby@BullyDog is an unknown quantity at this point
well i rolled the bike out today and it sounded horrible...back brakes were like stuck and rubbing bad...and by the feel of the rotor its been like that for at least one day...nice grooves
i took it off..pads are worn
so i put it back together..pump the brake up..and bam rubbing again
what gives? its just 2 bolts and some pads in there....and the wheel is lined up perfectly
so till i get dis fixed..no riding for me
any help would be great
thanx
_________
Old Apr 19, 2006 | 01:48 PM
Wheeliest's Avatar
Scrapes Elbow
Re: f3 rear brake problem..need help asap
pads rub constanly.. but if its making a pulse sound while you are riding its cause ur rotor is warped. if u apply the brake n u feel the pulse through the brake lever its most def warp.
Old Apr 19, 2006 | 02:06 PM
yea i dont feel a pulse
found the prob though
damn caliper is sticking..im gonna hone it out and put new pads on tonight..should fix it
Old Apr 19, 2006 | 05:59 PM
martino's Avatar
wheres all the fat girls
martino is a decent person
heres the things that can cause it to bind:
-caliper sliders frozen- use thick silicone lube on em
-caliper piston binding in bore-- see how well it pushes back with a clamp
-brake hose retaining pressure(like a one way check valve)-happens on cars all the time
-pedal not adjusted properly
good luck homie, i wanna see some pics that thing rockin
Old Apr 19, 2006 | 06:22 PM
well i figured it out
pads are really worn..so it wore down sideways..and when the caliper when to push on the pad..it went crooked trying to push the pad straight..so it would bind up and get stuck in the cylinder
i need a new rotor and new pads...anyone got a rotor lying around..mine is trash
Old Apr 19, 2006 | 06:23 PM
btw..heres a pic of me rockin the damn thing
Old Apr 19, 2006 | 06:24 PM
one more
Old Apr 19, 2006 | 06:30 PM
martino's Avatar
hell yea, nice man
Old Apr 19, 2006 | 07:19 PM
Wheeliest's Avatar
Scrapes Elbow
FIB
Old Apr 19, 2006 | 07:29 PM
eh...**** on you...im learnin
stuntin'_cbr
Nov 20, 2024 11:08 PM
blayl
Dec 3, 2012 02:17 PM
blayl
Nov 29, 2012 03:23 PM
unstopablee1
Oct 12, 2012 07:12 PM
Jay Carnes
Oct 17, 2002 03:25 PM
