fuel pump help
Old Mar 2, 2006 | 09:22 PM
cbrhomie's Avatar
cbrhomie is an unknown quantity at this point
fuel pump help
hey does anybody know how to change a fuel pump on a 01 f4i. any help would really help. thanks.
Old Mar 2, 2006 | 10:07 PM
stuntrider227's Avatar
stuntrider227 has much to be proud ofstuntrider227 has much to be proud ofstuntrider227 has much to be proud ofstuntrider227 has much to be proud ofstuntrider227 has much to be proud ofstuntrider227 has much to be proud ofstuntrider227 has much to be proud ofstuntrider227 has much to be proud ofstuntrider227 has much to be proud of
Re: fuel pump help
your in luck cause I just did this. First you want to order $8.00 rubber gasket from honda. mke sure it seats right and the 5 rubber tabs are pulled all the way through. The pattern to tighten is cross pattern on 4 side bolts then 2 end bolts. watch out and don't bend the lip in the tank or it will leak. find online parts fiche here. goto OEM parts finder www.yamahaoftroy.com
Old Mar 2, 2006 | 10:13 PM
Re: fuel pump help
here pic of fiche
Old Mar 2, 2006 | 10:18 PM
kj's Avatar
kj
Re: fuel pump help
and get yourself some of the #32 washers from that fiche... fuel line crush washers for when you crack the old lines. torque the banjo to 16ft/lbs
last thing ya want is a high presure fuel leak
--*CBR*KING*--
Apr 5, 2022 11:42 AM
big ben
Nov 10, 2013 06:16 PM
K6gsxr750
Sep 19, 2013 06:07 PM
freestylemotox
Jul 23, 2013 11:31 AM
blayl
Apr 7, 2013 09:44 PM
