R6 sub-frame problem
Old Feb 5, 2005 | 09:03 PM
atnuts's Avatar
it's an 02 R6 and the sub-frame bolts(especially the lower ones)keep coming loose I'm not even tapping the tail, just doing slow standups. I have to stop and tighten them after about a half hour of riding...any solutions outthere? post up...thanks
Old Feb 5, 2005 | 10:16 PM
catach42's Avatar
catach42 is an unknown quantity at this point
Re: R6 sub-frame problem
get 4 subframe bolts off of an f4i. they are longer and have nuts on the back so they stay tight much longer. i broke three of the stock bolts becuz they kept comin lose then i would hit the bar and they would snap, the f4i ones work mint
Old Feb 5, 2005 | 10:19 PM
Z-UNIT's Avatar
yah my f4i ones u ****
Old Feb 5, 2005 | 10:51 PM
atnuts's Avatar
will the nuts fit on the lower bolts? the way the frame is shaped the nuts won't fully tighten from the inside...at least not the nuts/bolts I was using.
Old Feb 6, 2005 | 10:53 AM
catach42's Avatar
im not 100% sure becuz i only have 2 f4i bolts and 2 random home depot bolts in right now. if the f4i ones wont fit then just get any old bolt, put it in there and crank it tight with a nut on the back, my lower ones almost never loosen up anymore and i only tighten the top ones every few ride and i use my bar ALOT
Old Feb 9, 2005 | 05:19 PM
sheetone's Avatar
sheetone is an unknown quantity at this point
maybe try some blue loctite?
Old Feb 9, 2005 | 05:54 PM
jmurrayR6's Avatar
jmurrayR6 is an unknown quantity at this point
lock tite bro
Old Feb 10, 2005 | 09:46 AM
Nick StuntMetal's Avatar
Nick StuntMetal is an unknown quantity at this point
get longer bolt's and put a nut on the end.
works for me so far.
im sure locktite is good too.
Old Feb 10, 2005 | 06:51 PM
Mr Weber's Avatar
Mr Weber is an unknown quantity at this point
True dat!! Unless you want to waste your money at the honda shop just so u can say u have F4i bolts!!!
Old Feb 10, 2005 | 11:04 PM
atnuts's Avatar
this is why I posted this question...weird frame angle I'm just thinking the nut should be flush against the frame on the inside. guess it doesn't matter. just picked up some longer bolts and nuts and gonna tigh it as far as it goes. check out the pic...guess everyone's doing the same???
bowflexmaverick
Oct 2, 2015 02:16 PM
alex71783
Aug 9, 2015 02:18 PM
Duke_Montes
Jul 23, 2015 11:12 PM
knowlzy0791
Apr 13, 2013 07:32 PM
