2nd gear sitdowns
Old Oct 8, 2002 | 02:32 PM
Tick_9se7en3's Avatar
Tick_9se7en3 is an unknown quantity at this point
2nd gear sitdowns
Yo guys, I've got my first gear powerwheelies down now and I'm getting better at 2nd gear standups by clutching them. I'd really like to learn 2nd gear sitdowns using the clutch so I can move on to tank wheelies. I clutch it somewhere between 5-6K rpm but the front only comes up about 6in or so. Should I be really wacking the throttle or is my technique fucked up? Just trying to get some feed back before I go out and pratice again.
Old Oct 9, 2002 | 12:04 AM
PRESTON's Avatar
PRESTON is an unknown quantity at this point
more throttle
The bike has to come with less help when you are sitting down. Just give it a little more throttle, try it around 6-7RPMs. Also, put your *** against the rear seat.
Old Oct 9, 2002 | 11:18 AM
jmacdaddyt's Avatar
jmacdaddyt is an unknown quantity at this point
If the tire is already coming up 6 inches then just give a little more throttle once it lifts off the ground. You should have no problem. Most people lean forward and do not realize it causing the front to come back down. Do as twisted said and sit toward the rear, also use only 1/4 to 1/2 tank of gas. Keep practicing, it will come in time.
Old Oct 9, 2002 | 12:32 PM
GSXR Nick's Avatar
GSXR Nick is an unknown quantity at this point
I also getting good at powering it up in first, and no Im trying to clutch it up in second gear. When I rev it up do I let the clutch out gradualy or do I just let go. Im still learning, thanks in advance.:cool:
--Nick--
Old Oct 9, 2002 | 10:50 PM
PRESTON's Avatar
--Nick--
Do not fully engage the clutch. You only need to pull it in about 1/8 to 1/4 of an inch. Get rolling to around 60 mph pull in the clutch as stated and let it go as you hit the throttle with a good twist.
Old Oct 10, 2002 | 10:28 AM
jmacdaddyt's Avatar
Damn twisted right again!
Old Oct 10, 2002 | 10:40 AM
Raybone's Avatar
Raybone is an unknown quantity at this point
on my r6 i really have to pound on the throttle to get a second gear sitdown up...it takes alot more than a standup but it will do it just takes a little more beating on the ol' yammi
Old Oct 10, 2002 | 02:36 PM
GSXR Nick's Avatar
Thanks for the replies. Now if I wanted to try it standing up, what is the best way to do it. Thanks
Old Oct 10, 2002 | 10:24 PM
willie's Avatar
willie is an unknown quantity at this point
i get from about 6-8 grand, under a quick acceleration, shut the throttle while compressing the front forks- bouncing as it's referred to here, then wack it to 75-100 perecent throttle, lean back a little bit and up it should come.
i can do it without a clutch on a 96 f3, so your bike should do it without a clutch to
i could do it with stock gearing, but now i'm one down for the front tooth and it's even easier.
Old Oct 10, 2002 | 11:19 PM
PRESTON's Avatar
Basically the same way as the sit down. The only difference is you don't have to use the clutch when you are in second gear. Just give it good bounce and on the rebound twist the throttle and give it a pull up. Don't lean forward when pulling that defeats the purpose. Just stand up straight and pull the bike to you.
Now, if you try it in third gear, do the same as explained above but use the clutch method. Some like to use the clutch and some dont. I prefer to because it takes less RPMs to get the bike up.
Old Oct 10, 2002 | 11:20 PM
60??? DAMN.
I clutch up 2nd gear sitdowns between 20-40mph.. sometimes as low as 15
Old Oct 10, 2002 | 11:26 PM
PRESTON's Avatar
thanks, now if I can figure out how to do 12's without destroying my bike would be great. \
I learned to do the sit downs and stand ups on my own, that is why I can explain them well, but 12's, damn them suckers,you definitely need to ask.
Old Oct 10, 2002 | 11:30 PM
PRESTON's Avatar
Originally posted by nags
60??? DAMN.
I am with you nags.
he is just starting to learn. I am just letting him use the torque to get it up. Once he figures it out, then he should be able to whip up at lower speeds with less torgue.
Old Oct 11, 2002 | 12:00 AM
rotgg's Avatar
rotgg is an unknown quantity at this point
hit the throtle and pull on the bars some
Old Oct 12, 2002 | 02:38 PM
GYNXxx's Avatar
GYNXxx is an unknown quantity at this point
Putting your *** to the very back of the seat makes a HUGE difference ...it may feel a little weird at first being more stretched out ..but it also lowers your balancing point so you dont have to go as high ( at first that is)
stuntsquid101
Jul 24, 2016 09:51 PM
musicman3x
Nov 20, 2015 12:01 PM
Jacob Payne
Sep 28, 2015 01:41 PM
FreedomPenguin
Sep 8, 2015 02:06 AM
musicman3x
Jul 14, 2015 08:17 PM
