Need Help Building My K7 Gsxr
Old May 9, 2009 | 06:54 AM
CoRdYdIcE's Avatar
CoRdYdIcE is a decent person
Re: Need Help Building My K7 Gsxr
bump bump
Old May 9, 2009 | 12:11 PM
Dick Loogie Stunts's Avatar
www.myspace.com/impaktech
Originally Posted by loogie
first you should locate the search button and USE IT but since your a newb ill help you out...do the pair mod,TRE mod,SET valve mod,get a stunt throttle kit,get a hohey HB dual caliper HB,flip and switch stock clip ons,get a moose ez pull clutch setup,beat your mint tank in,and shitcan whatever cage/subcage your running and get a Impaktech cage/subcage/roundbar/"nate plate",and shitcan your stock tail for a 1piece one that wont blow apart,get a stabilizer or change oil in stock one to 50 wt.,cut down your mint upper/windscreen to accomodate controls,cut a hole in your mint rear seat,get an ez circle button from HAI and mount it on left clip on,blah,blah,blah....hope this helps and good luck!!!ill see you on the freeway with a snapped in half frame!!!
what else is there to know????i gave you the run down already in my post abovedo what i said and go do work son!!!
Old May 15, 2009 | 09:47 PM
EthanK's Avatar
EthanK is a decent person
bump.
Old May 16, 2009 | 06:12 AM
katana1100's Avatar
katana1100 is an unknown quantity at this point
hi
I have -1 front and +12 rear. It´s ok to me.....
Old May 23, 2009 | 08:42 AM
EthanK's Avatar
bumpp
armenta818
Jun 19, 2013 08:23 AM
ducKhunt
Dec 12, 2012 04:44 PM
berencam
Nov 11, 2012 07:19 PM
