Need Help Building My K7 Gsxr
I have a K7 gsxr that Im trying to turn into a stunt bike. But I dont have any ideas to start from. I got a cage and subframe cage thinkin about buyin a hohey handbrake.I want to run clipons instead of db. I just want to get some more info on parts and what mods I need to do to my bike.If theres anybody that stunts on a gsxr can you help me out thanks...
Re: Need Help Building My K7 Gsxr
I would definitely buy one of these
https://www.stuntlife.com/forums/464...impaktech.html
I had an 06 when I was learning and I broke my subframe every 2 or 3 weeks gorilla scraping
Subframes on those bikes are weak sauce.
Subframes on those bikes are weak sauce. Re: Need Help Building My K7 Gsxr
but since your a newb ill help you out...do the pair mod,TRE mod,SET valve mod,get a stunt throttle kit,get a hohey HB dual caliper HB,flip and switch stock clip ons,get a moose ez pull clutch setup,beat your mint tank in,and shitcan whatever cage/subcage your running and get a Impaktech cage/subcage/roundbar/"nate plate",and shitcan your stock tail for a 1piece one that wont blow apart,get a stabilizer or change oil in stock one to 50 wt.,cut down your mint upper/windscreen to accomodate controls,cut a hole in your mint rear seat,get an ez circle button from HAI and mount it on left clip on,blah,blah,blah....hope this helps and good luck!!!ill see you on the freeway with a snapped in half frame!!!
We can do whatever kit you would like. A popular stunting kit we sell, is the street stunt kit. http://www.thestuntfactory.com/ststdrkit.html
you shoulda listened
