Fork Oil Wt.?
Old Apr 20, 2009 | 07:49 PM
Stubbz's Avatar
Fork Oil Wt.?
What weight fork oil do you guys run? Is a lighter weight fork oil less likely to blow fork seals doin a lot of stoppies, i know my 07 600RR is known for it and mine just blew with 7k miles on um.
Old Apr 22, 2009 | 10:30 AM
Stubbz's Avatar
Re: Fork Oil Wt.?
Bump....
noone..
Old Apr 24, 2009 | 02:54 AM
NME's Avatar
NME
NME is a decent person
Re: Fork Oil Wt.?
I ran 20 in my 929
Old Apr 24, 2009 | 02:59 AM
Re: Fork Oil Wt.?
15 here
Old Apr 24, 2009 | 09:02 PM
Stubbz's Avatar
Re: Fork Oil Wt.?
isn't the heavier the oil more likely to push on the seals and ruin them from hard hits?
I have the Level X video How to stoppie by Kyle Woods and Bill D and Bill D says he changes it out to a 5wt. to help not blow seals as fast.
Just curious if others have tried different variables and what works best
Old Apr 25, 2009 | 02:02 AM
NME's Avatar
NME
Re: Fork Oil Wt.?
I've never blown one. Quite a few people here will tell you how **** i am about forks. If you're serious about stoppies, you'll rebuild them a few times a year and they wont have a chance. I dont think heavier oil will push by the seals any easier than thin. Too much may. They usually leak because of debris getting under them. Then the longer you ride on leaking seals,the more your forks will leak and be more likely to leak even after they are repaired. They will develop vertical scratches on the extension tubes and always leak. Keep up with them and you wont have problems.
Old Apr 25, 2009 | 03:00 AM
Re: Fork Oil Wt.?
end of thread
Old Apr 25, 2009 | 06:01 AM
da Liks's Avatar
da Liks is a decent person
Re: Fork Oil Wt.?
indeed.
Old Apr 25, 2009 | 09:31 AM
Stubbz's Avatar
Re: Fork Oil Wt.?
good enough answer for me.
Old Apr 25, 2009 | 09:47 AM
shoyass's Avatar
shoyass is a decent person
Re: Fork Oil Wt.?
I rebuild them with a blend we come up with. Its called 20W50 full synthetic (No wait, Sorry to take credit for the motor oil companys) Haven't had one come back yet. I don't care what you do you are not blowing that stuff through any thing but a crack
joeybaila
Nov 9, 2020 05:52 AM
C-Dub
Jun 12, 2013 11:44 AM
Ryan Colbert
Feb 28, 2013 01:29 AM
quentinludwig
Feb 27, 2013 10:55 PM
