Air box mod !!!
Old Jan 24, 2009 | 09:11 AM
B,Boy's Avatar
B,Boy is a decent person
Air box mod !!!
Allright lads i just got a F4i last week and ive done the idle mod and the air box mod and the tilt switch and i still cant get it to run right ive tried adjusting the stock idle cable up and down with no luck ive read the sticky a number of times and everything is done as said but when i get to BP the bike just bogs down !!!!! anyone any ideas ?????
Old Jan 28, 2009 | 05:34 AM
B,Boy's Avatar
Re: Air box mod !!!
Anyone any ideas
Old Jan 28, 2009 | 05:46 AM
StrictlyStunt's Avatar
Re: Air box mod !!!
vacuum leak somewhere....
check to make sure all the air box holes are plugged. Makes sure all the lines are tight and that you didnt miss anything.
Old Jan 28, 2009 | 11:45 AM
287ridah's Avatar
F*(K Yut Uggh
Re: Air box mod !!!
You missed something or the fuel filter, fuel pressure regulator is bad. Most likely you missed a vacuum leak though. Its especially a vacuum leak if it was working fine before you did the mod.
Old Jan 29, 2009 | 04:58 AM
B,Boy's Avatar
Re: Air box mod !!!
Think i got it fellas was still running the top faring with full lenght air intakes , took them off last night and tried it seems to be better just have to adjust second cable now
thanks for the help !!!
Clutch n' Chris
May 23, 2013 05:06 PM
Criscone24
Apr 16, 2013 05:29 AM
xxSHANNONxx
Jan 22, 2013 10:57 PM
njstunt855
Dec 18, 2012 12:43 PM
StreetRacr 67
Oct 20, 2002 02:23 PM
