f4i with 04 1000rr front forks
hey i have an f4i with 04 1000rr frontend on it, i was just wondering before i buy a gpr if the f4i gpr bracket will still work with the 1000rr upper triple. someone on here has had to have done this???
Re: f4i with 04 1000rr front forks
yea it will with alittle cutting to the top triple,due to it came with a stock damper mounts on it...then you would have to shave down a ring around the triple stem on top so that the damper mount sits flush.....
