need help learning Endos
ive heard all types of things like go 35 then apply the brake then squeeze or go 30 then squeeze the brake and hump the tank. i just want to kno the best way to learn so i can start with gettin tha back tire off tha ground and then on to rolling them out for a lil distance
Re: need help learning Endos
I would say to get a dirtbike, so if you go over you just hit dirt, but its the same basic concept either way. The faster you go the longer you will go or faster you will flip, so in starting the slower the better. First make sure your comfortable with getting on your front wheel and you can keep your balance good. So do stoppies to jsut practice. Then, once you move on you just speed up and grab the front brake enough to pull the back end up to Balance Point, right before you get there you should let the front brake off jsut a tad so your wheel will spin but there is still a bit of friction. That should let you ride it out while your up. When i say grab, do the same thing that got you to do a stoppie to practice standing still. I am not the greatest teacher as i still dont have my sportbike stunt skills up to par, but i can do a lot on my pitbike and everything has the same basic concept soooo good luck with it
so I flipped over the bars today it does hurt when you hit the deck and then again when the bike hits your pip later on I disscovered it was easier to go faster and use less brake it is smoother and you dont have to be as high to roll them out ya have to just say fuckit and do it
check out the link it has some good info on rolling endos http://www.uponone.com/viewhowtos5.php
