I Need Help With My 02 R6 Its Weird
I Am Having Problems With My R6 It Dont Have Any Plastics Or Front End At All When I Try To Do Wheelies It Boggs Down Bad I Dont Know If It Is Because I Dont Have Enough Air Because It Is Very Rich.i Have Not Put Any Jet Kits In What So Ever I Am Thinking That Since I Have No Ram Air Induction On The Front Plastic Air Ducts Because I Have Them Off The Bike Because I Want To Stunt It All Out So I Want To Know If Anybody Has Had The Same Problems With Their R6 When They Stripped It Down Completely Streetfighter When I Drive It On The Road I Slowly Accelerate And It Pics Up Speed But When I Just Punch It It Boggs Down Very Bad Like It Dont Want To Move At All . So I Just Want To See If This Is A Problem From Me Not Rejetting Out The Bike To That Certain Spec Without Fairings I Just Have The Holes In The Frame Thats All The Passage I Have For Air To The Airbox To Recieve If Somebody Can Help Me I Will Really Appriciate It Cause I Have A Show Coming Up And I Have Never Had This Problem Before This Is My First 02 Yamaha R6 Thanx Crazzy B From The Cyclone Stunt Team I WOULD REALLY APPRICATE IT IF WHOEVER HAS HAD THIS PROBLEM BEFORE LIST ALL STEPS THAT THEY DID TO FIX THE PROBLEM LIKE WHAT JETS TO USE OR WHATEVER I WOULD REALLY APPRICIATE IT THANX I JUST WANT THIS BIKE TO PERFORM AT MAXIMUM POTENTIAL!!!!!!!!
Re: I Need Help With My 02 R6 Its Weird
I got my 01 R6 ran on a dyno when I picked up some new pipes cheap off ebay, I also run no fairings etc and it runs alright but I apparently need to get the carbys serviced (float heights asjusted I think the mechanic said) cause it bogs a bit when you go from no throttle to full throttle. Dyno gives you fuel/air mixture results and some info to go by to narrow the search for the problem a bit quicker imo
sounds like you have some plugged up air jets or suntin of that such, take carbs apart remove all jets and blow air through them all then reinstall if it does the same you need different jetting almost certainly
