Help: Wireing Acerbis Light
Old Apr 4, 2007 | 06:03 PM
Charlie636's Avatar
Charlie636 is a decent person
Im just about finished doing a few things with my bike.. but i cant seem to wire up my Acerbis Diamond Headlight. for my 636
I've used to search but cant seem to find what im looking for.
If anyone has any diagrams or help .. greatly appreciated!
Old Apr 4, 2007 | 10:56 PM
Charlie636's Avatar
Re: Help: Wireing Acerbis Light
anyone
Old Apr 4, 2007 | 11:04 PM
do you still have your left hand controls ?
if so just use the factory wires for the stock head light if not run some wires directly to the batt with an inline fuse and a toggle switch
Old Apr 5, 2007 | 09:59 AM
Charlie636's Avatar
i do still have the factory headlight wireing.. thats what im hooking it up too . just dont know which one goes where n ****
Old Apr 5, 2007 | 11:51 AM
on a 636 the head light only gets power once you have hit the start button so turn on your key hit your start button then turn the bike off with the kill switch not the key and then just use a test light [or your acerbis] to figure out which wires have power...
p.s make sure you check with the high low beam switch in both positions so you know which is high and which is low
Old Apr 9, 2007 | 09:15 PM
trae's Avatar
trae is an unknown quantity at this point
Get a toggle switch and run a wire from the battery then run a ground wire to the frame. Thats what I did and I can still put the stock upper on and not have to **** around with redoing wires.
Old Apr 13, 2007 | 01:54 AM
Wheeliest's Avatar
Scrapes Elbow
^^^ this kids a ******* idiot.
VXscOOter
Jun 22, 2013 02:31 PM
Kerns BBO
Apr 29, 2013 12:34 PM
jrock1023
Jan 11, 2013 11:58 PM
eamonhoffman
Oct 14, 2012 07:51 PM
