Running a 2-stroke in reverse
Old Jan 12, 2007 | 06:07 PM
Reyals Bemus's Avatar
Hey, how do I run a 2-stroke engine in reverse? Is it just a matter of flipping the puller so you pull-start it backwards?
Any help appreciated.
Old Jan 12, 2007 | 06:09 PM
og ryan lee's Avatar
You seen Philo Beddoe?
og ryan lee is an unknown quantity at this point
Re: Running a 2-stroke in reverse
you would have to change the timing for sure...
the timing needs to be adjusted ....
use to have a golf cart with a two stroke and thats how reverse worked
Old Jan 12, 2007 | 06:12 PM
Well, is there anything online that could help me with this?
Tutorial, article or something?
Old Jan 12, 2007 | 06:13 PM
what is the engine on...what kind of engine
what are you trying to do?
playing a dirty dirty trick on someone?
Old Jan 12, 2007 | 06:16 PM
if the timing is set at 8 degrees advanced then you would have to retard it 16 degrees ...
and it must not be the type that has mechanical advance or it will be retarding it self while in reverse
No I just have a small 5 hp 2-stroker that my friend gave me. I'd like to see if I can get it to run backwards!
Old Jan 12, 2007 | 06:17 PM
GSWITCH33's Avatar
Senior Moderators
What is the point? I mean really
Old Jan 12, 2007 | 06:18 PM
Ok umm sorry but what does this mean?
Just to learn stuff.
Old Jan 12, 2007 | 06:19 PM
oh ...then just find where the timing is set and retard it the same amount as it is advanced,once your at zero that is
roger......
your knowledge is impressive.
Old Jan 12, 2007 | 06:22 PM
just pull the rope if it doesnt have too much timming it might start without doing any thing
Old Jan 12, 2007 | 06:23 PM
ryan you can tell we both like the two stroke bikes that are dissapearing ..thanks to the epa
Old Jan 12, 2007 | 06:29 PM
yeah the dirty **** suckers....
i miss my cr500.
Old Jan 12, 2007 | 06:31 PM
braaaaaaaaaapppp
does it have points or a cdi ignition?
so whats up bemus did it start ?
Old Jan 12, 2007 | 06:32 PM
dont confuse him
