Running a 2-stroke in reverse
Old Jan 12, 2007 | 06:33 PM
og ryan lee's Avatar
You seen Philo Beddoe?
og ryan lee is an unknown quantity at this point
Re: Running a 2-stroke in reverse
yeah really... i was gonna tell him to look for a timing mark on the flywheel, too...
Old Jan 12, 2007 | 06:35 PM
damn it i wish he would just pull the rope i wanna know if it started it should if it doesnt have too much advance
Old Jan 12, 2007 | 06:39 PM
pull it
pullll iiiiiiiiiiiiiiiiiiiiiiitttt
Old Jan 12, 2007 | 06:41 PM
hookers on the way home with dinner... i will be back in a few Roger... gotta shower
Old Jan 12, 2007 | 08:19 PM
Reyals Bemus's Avatar
I know how to work on engines and stuff. But my experience with 2-strokes specifically is lacking. I know what a flywheel and points are and all that stuff.
This engine does have points, it came off a fairly old push-blower. Nothing advanced. Just the engine, carb, and gas tank.
Old Jan 12, 2007 | 08:23 PM
I had originally figured that I could just flip the pull rope, and yank it, but got to lazy to go pop the rivets holding the cover over the pullstarter.
So I'm just asking here first so I can know what needs to be done to make it run backwards well.
_____
EDIT: Alright I'll go down and flip the rope and yank it. I'll keep this posted.
Old Jan 12, 2007 | 10:31 PM
the pull start isnt gonna work backwards i bet because of the clutch or sprag............over two hours since his last post..lol
Old Jan 12, 2007 | 11:04 PM
brucer6's Avatar
brucer6 is an unknown quantity at this point
on skidoo snowmobiles that is how reverse works you push the button and it shuts it off and it restarts backwords
Old Jan 13, 2007 | 01:36 AM
DWJmoto's Avatar
DWJmoto will become famous soon enough
I always wanted to start a dirt bike up backwords but never tryed it
Old Jan 13, 2007 | 04:16 PM
Ned's Avatar
Ned
Ned is an unknown quantity at this point
I once saw an old Maico dirtbike start backwards
Old Jan 13, 2007 | 06:15 PM
There's no clutch.
I'm telling you guys, this is literally just THE engine I bolted to a bench. It's got a carb sticking out of it with a tank I hung above it. I cut the exhaust so it's basically straight out the block. (Yes I know 2-strokes don't run as good this way) It runs perfect in its normal direction.
Old Jan 13, 2007 | 07:17 PM
did you start it backwards yet ............
and i meant the pull start clutch or sprag its designed to work in one direction
Old Jan 13, 2007 | 09:40 PM
  #33
Herb's Avatar
Herb is an unknown quantity at this point
Very mechanically inclined Mr. Roger
Old Jan 13, 2007 | 10:36 PM
  #34
i had an 83 rm125 that started backwards one time after i dumped it and i revved it up thinking that it was loaded up from being upside down... it ran like **** but it was running backwards..
Old Jan 18, 2007 | 07:58 AM
  #35
Lukas's Avatar
Lukas is a decent person
I knew a guy that crashed when his old peace of **** 2 stroke moped randomly started going backwards when he realesed the clutch I wish someone would film it I heard that on some oooold bikes u can just simply push start it, but when ur pushing the bike backwards...good luck
steelcityrider
Jun 18, 2013 01:04 AM
Zcress
Jun 1, 2013 11:21 AM
zeus_r6
Apr 2, 2013 04:26 PM
junior07
Feb 24, 2013 02:48 PM
junior07
Feb 24, 2013 02:21 PM
