Disc brake pads are too close
My front disc brakes just keep squeaking cause the disc is touching the pads. I don't know how to separate the pads a little more. They're way to close together. I've already run a few searches in Google, but found nothing. Maybe another one of you 150 riders here can lend me some specific help. But any help is appreciated! Thanks.
Re: Disc brake pads are too close
dude i'm pretty sure that there will always be some very slight contact even when brakes arnt applied. but if they are dragging more than normal, mabey check your piston or slide bolts? also check your brake fluid if its old and possably boiled. hope this helps bro
yeah they will be touching always but liftit up and se if the wheel spins pretty free, if it does just clean all your dust away and your good, if not then you either got a caliper sticking or the slides are sticking or a bent rotor
2005?
How often do you ride in the dirt, and how often do you clean it?
a bike that new shouldn't have stuck calipers, or bad fluid...
Hell my 1995 fzr's brakes were fine, still from the factory never touched! Only had to rebuild the rear caliper, but the front was fine.. and thats after 10 years
That's probably what it is. All the dirt and mud pwned my brake system, and now I'm noticing. I'll just clean it, cause for the recent few months I haven't touched dirt. All street and lots now.
