Shifting from first to second? should i clutch?
have been trying to learn to shift to second. and what i have been doing is trying to hit the BP and then clutch in and shift to second.. but everytime i clutch I drop..
should i just be letting off alittle and hit second and power shift then throttle on hard again? when im seeing it my head im thinking ill loop cause ill be at a high rpm..
whats up
whats up
Re: Shifting from first to second? should i clutch?
dont use the clutch get it up in first and as you feel it going down use all the left over power you got to get you high to balance point and change to 2nd without just wack it in and put the power on so my advice get it high enough and dont use clutch
nah just keep it in first and bring it back past bp and slow it down so you don't need to go into second.... you shouldn't be learning on any kind of road where you need to go that fast anyway
btw standups are much easier to learn than sitdowns.... read the sticky thread in the help how to section... the basic guide for learning wheelies
So no clutch.. thanks
I know how to wheelie.. and i know i dont need to go fast.. but its a skill that i dont know and want to know.
once you get it down smooth with no clutch, start tryin to use the clutch, cause when you start tryin to shift from 2nd to 1st, you're gonna have to use it
Originally Posted by da Liks
then why the FU CK are you scared to loop..
im not scared too loop.. but id rather not do it going into second gear at like 60K
learn to whoolie the safe way then you won't even be asking these questions.
Oh and your not at BP
or else that front end wouldn't be falling when you pull in the clutch.
or else that front end wouldn't be falling when you pull in the clutch. Re: Shifting from first to second? should i clutch?
or else that front end wouldn't be falling when you pull in the clutch???
NO ****!?! I was wondering why my wheel comes down..
or else that front end wouldn't be falling when you pull in the clutch???NO ****!?! I was wondering why my wheel comes down..
wha? lean to wheelie the safe way? what are you talking about..
im not a power wheelier.. I just want to know how to shift while in a wheel.
lets skip the parental lectures here. all i ask is do you use the clutch or not
