I NEED F4i ELECTRICAL HELP!!!!!!!
Old Jul 17, 2006 | 04:32 PM
TongWoo's Avatar
Came back-it's still wack
TongWoo will become famous soon enough
Here's what happened...
Just went to start up my bike...NOTHING.
So, thinking the battery is dead, I roll started it...
It started but is cutting on and off.
I get back home, and my switch that I had the headlight hooked up to is smoking...I unhook it... It was straight off the battery to the switch then to the light.
I try to start it...Nothing, then I get a clicking from the starter relay... I replace the starter relay... I still get the same clicking...AND THE FUEL PUMP IS NOT PRIMING...
okay, we know it's prolly not the ECU because it prolly wouldn't have roll started...ALL MY FUSES ARE GOOD.
I haven't found any melted or smelly burnt areas in the harness yet.
You think it's in the harness, a short in the battery, or something else?
Also, what if the battery discharged so much that it will only click the relay...? Seems like the fuel pump would still try to prime...
HELP! I got shows to do!
Old Jul 17, 2006 | 06:22 PM
teva's Avatar
teva is an unknown quantity at this point
Re: I NEED F4i ELECTRICAL HELP!!!!!!!
Sound like a dead cell in the battery? Have you tryed to jump start it? or swap batteries/...
Old Jul 17, 2006 | 06:37 PM
KROHNSTUNTS's Avatar
AuthorityStunts
KROHNSTUNTS is a splendid one to beholdKROHNSTUNTS is a splendid one to beholdKROHNSTUNTS is a splendid one to beholdKROHNSTUNTS is a splendid one to beholdKROHNSTUNTS is a splendid one to beholdKROHNSTUNTS is a splendid one to behold
batt is junk for sure( ithink ) haha
Old Jul 17, 2006 | 06:52 PM
MR. RYAN SMITH's Avatar
Fuel Pump Not Coming On: Ignition Switch(or Diode Inside), Right Hand Switch Assy, Safety Circuits(clutch Switch, Ss Switch). If Your Headlight Harness Was Smoking Try Jumping The Required Wires Before The Connector On The Main Harness Side. Sounds Like You Are Over Thinking It, Look For The Easy ****.
Old Jul 17, 2006 | 09:35 PM
TongWoo's Avatar
Thanks for the advice everyone! I found 2 wires that were grounding out, and my battery wouldn't take a charge. Got it all fixed now... It was a pain in the *** finding the wires... There was no melted area or odor...but I found em... Hells yeah.
junior07
Jul 17, 2013 10:37 AM
knowlzy0791
May 6, 2013 05:41 PM
gotafurrybike
Feb 7, 2013 02:27 AM
JFLACO610
Feb 1, 2013 09:27 PM
