NEED HELP WITH 2nd GEAR WHEELIES
Old May 17, 2006 | 01:48 PM
gsxrboi02's Avatar
gsxrboi02 is an unknown quantity at this point
I can't pop a wheelie in second gear on my 05 GSXR 600. I slip the clutch and catch a tad bit of air but I would have to roll on the throttle really really hard to have it come up at all. I bounce the bike and it comes up but only a few inches. What am I doing wrong??? Also, is there a "how to pop 2nd gear wheelie clips online"?
Old May 17, 2006 | 01:53 PM
Wheeliest's Avatar
Scrapes Elbow
Re: NEED HELP WITH 2nd GEAR WHEELIES
u just gotta keep practicing.
Old May 17, 2006 | 02:35 PM
grizzy225's Avatar
grizzy225 is an unknown quantity at this point
its not really a roll on motion for me.. i gotta give it a nice ol twist. but dont do to much to fast or u'll be on your back. just try it over and over, keep the rpm's up then just pop and twist. take a bit to get used to. ive been wheelin few days now and im gettin it down alright. takes time.
http://s47.photobucket.com/albums/f1...ingvids006.flv
Old May 17, 2006 | 02:43 PM
crtchrktrcr's Avatar
B.T.M.
practice and give it more gas... baby steps.. try standing too
Old May 17, 2006 | 03:37 PM
gsxrboi02's Avatar
Do I just pop the clutch??? No need to bounce the bike?? I'm on a GSXR 600. Also, do I need to pull the clutch all the way in? <---(I usually use only 1 finger to pull the clutch in.) Also, what rpm or speed should I be going before the bike can catch some air?
Old May 17, 2006 | 04:27 PM
grizzy225's Avatar
Im ridin on a 900rr. 1 tooth down in the front and stock rear. What i found out is if i bring my speedo up to 60mph/6500rpm, pull the clutch in(1 finger all you should use) and pull the throttle while letting out the clutch up it goes without a problem. Thats my second gear wheelies, dunno about anyone else. and try doing a stagard stance. it does feel VERY awkward at first but do it in first gear a couple tries then see how it feels in second. its MUCH more comfortable and easier to balance/steer.
Old May 17, 2006 | 05:25 PM
JOHN J's Avatar
IDLE WHORE
JOHN J has a spectacular aura aboutJOHN J has a spectacular aura about
keep practicing and sit all the way back on your seat it will help alittle
Old May 17, 2006 | 06:43 PM
B.T.M.
false.. hug your tank.. less wobbles that way.. n yes pull it in all the way.. burning the clutch wont help
Old May 17, 2006 | 07:21 PM
dcb71 is an unknown quantity at this point
When I raise it in 2nd I try to make my arms feel like they have very little downpressure against the bars then as I slip the clutch and yank like you want it to come up get a good slip on the clutch keep your body moving as it comes up raise it to bp. Timing is everything practice it will come.
Old May 18, 2006 | 03:25 AM
sWiFtY 50's Avatar
sWiFtY 50 is an unknown quantity at this point
i have a f4i. I bounce the **** out of mine and give it a good amount of gas. It took me awhile to get it up to decent bp but now I can't believe how easy I can do it. I just bounce and right when I start to come out let the clutch out while revvin it prettty good and it comes straight up. Only reason it took me so long is because I was used to doing 1st gear wheelies and didnt wanna loop it. But you definately have to rev it up more in second gear.
Old May 18, 2006 | 03:29 PM
gsxrboi02's Avatar
So it goes like this: Pull clutch in-bounce-drop the clutch-and rev the **** out of it? I won't loop it unless I roll the throttle back all the way right...??? Or can I loop the bike going 45mph? What speed should I hit this at???
Old May 18, 2006 | 03:49 PM
Justin-'s Avatar
Justin- is an unknown quantity at this point
That is true close to the tank and push down and pull up and dump the clutch even in s sit down if u r doing stand ups then bouse that B!t[h and the dump the clutch
Old May 18, 2006 | 03:52 PM
Justin-'s Avatar
u need to get the feel for the bike, i can tell with the ? u r asking. r u tring to us the rar brake at all(not really to slow it donw just to be safe?
Old May 18, 2006 | 06:25 PM
gsxrboi02's Avatar
Haven't used the rear brake at all. Tried standing on a couple of 1st gear ones but I'm more comfortable doing them sitting down. I can ride 1st gear wheelies out with just the throttle but I haven't touched the rear brake yet. I can't shift gears when doing wheelies either. Should I start practicing how to stand on my 1st gear wheelies before I move on to second gear?
Old May 18, 2006 | 07:23 PM
xxxmen007's Avatar
From: Warensburg Mo/Kansas city MO balad Iraq till feb07
xxxmen007 is an unknown quantity at this point
I've wheelied two 600 gixxers a newer one and a older one, just more gas and the clutch, no need to bounce or anything. just get use to it through practice.
Old May 19, 2006 | 06:49 AM
bruno_z's Avatar
it's all about the timing. but i suggest you better learn 1st gear and RB first...
Old May 19, 2006 | 05:41 PM
Stunter-X's Avatar
Stunter-X is an unknown quantity at this point
I think 2nd is way easier. There is more chance of you looping it in first. I'd just keep giving it more and more gas til it comes. That bike should have no problem.
Old May 19, 2006 | 05:52 PM
Scott982's Avatar
Scott982 is a decent person
just keep practicing and you will get it just cover the brake and take it slow..
Old May 20, 2006 | 03:53 AM
Puer's Avatar
Puer is an unknown quantity at this point
just remember not to pull it so hard when u go back to first
Old May 20, 2006 | 04:04 AM
B.T.M.
wow.. dont even try.. ride more first.. the point is to rev while the clutch is in.. you can loop at any speed
