slip clutch or not in circle wheelies???
i can do circels but after i do a couple i stall
so i was thinking slip the clutch or not???
and how do you do it right???
all tips are welcome.
and what is a good hb setup to use the clutch and handbrake at the same time?
Re: slip clutch or not in circle wheelies???
I can only get 1 circle without slipping the clutch, but guys who are real good dont need the clutch at all.
When you get too high, pull in the clutch and use some brake. The front will start to come down without the bike stalling. As soon as the forks start to point down, let the clutch out, and possibly give it some gas and circle some more.
I couldnt tell you about the clutch/hb together
Originally Posted by gixxer6000
ok i will try it
thanx for the help
thanx for the help
