Oil Problem
Oil Problem
Went Out Riding Today And Usually Just Stay In A Lot But Everyone Decided To Hit The Streets For Alittle. Vortex Sent Me The Wrong Spocket So Im Still Waiting On It But Just To Ride I Have -1 -3thats The Only Size Back Sprocket They Had @ The Shop So I Took It Just To Ride. Has No Power @ All Can Only Do 1st Gear Stuff But The Bike Runs @ High Rpms. Already Did The Air Box Mod So, Then 3 Wheelies Into It The Bike Starts Smoking Like A Train. Everyone Was Saying Some Oil Got Into The Head So I Just Rode For Alittle And It Stopped. Checked My Oil Later And I Hd It Filled Past The Marker Line On The Dip Stick And Know It Looks Like Most Of It Is Gone I Guess From Burring Cause There Was Bubbles In It. Runs Fine Now But I Was Thinking Am I Gonna Need A Oil Pick Up To Solve This Problem ? Sorry This Is So Long
Re: Oil Problem
a bike that is over filled will smoke with the clean air mod but at least the oil is going straight out th exhaust instead of going in your air box and blowing up your motor....
Re: Oil Problem
you need to do the crankcase oil vent mod u must re route it to the top of the motor into the cam cover! look it up i didnt do it on my r1 and blew that sumbitch up u must redo the oil lines in order to stunt the bike it gets into the airbox and is sucked through the throttle bodies or carbs and is injected into the cylinder and the motor cant compredd liquid it can only compress air
Re: Oil Problem
Re: Oil Problem
[quote=o0kawi_boi0o;3284351]dropped it once before the clean air mod and had alittle oil in the air box but havent dropped it since then
pull your air filter and see if its covered in oil....fell off mine and somehow my air filter was covered in oil
Re: Oil Problem
[QUOTE=TexRida;3285498]when i first dropped it there was alittle oil in the air box when you drop the bike
